J32A2 with 6 Speed Swap
Okay, I finally found the J32A2 with the 6speed for sale. Took me forever. Now, aside from the motor/tranny, what else would be needed to get this to work, and how much for those parts? :dunno:
Also, does anyone know of any shops that you can HIGHLY recommend on doing a swap they have never done before. I really want to see if this swap would be worth it, but just trying to do my homework before I buy this motor/tranny. Does anyone think it can ALL be done for 5 grand? If so, then I'm down to do this right now. |
5 grand for installation and the parts> or what exactly....do you mean by ALL>...as in install and parts? i thought it was more around 7-8k from what ive been seeing
How much are you getting the J32 and tranny for?
Yea, install and parts. Is 7-8k what I should expect? If so, then I'd have to actually think if it'd be worth it for me. But it's either that, or get rid of my car, and then have to pay monthly payments on higher insurance, and car payments, which I really don't want.
I emailed the guy. I have to wait for his reply. I couldn't tell if he was selling the motor and the tranny for $3500, or just the motor. But it seems to me like it was both for $3500. I just want to double check that. The motor has 30k on it. :)
who will you have do the install?
I suggest these guys www.streetimage.com Hope to see how it comes out :) |
Arghh! But I need to know what else woud be needed. I don't want to get everyone siked up about this just yet. Aside from motor/tranny, what else do I need? And how much am I looking to spend ALL together for parts/install?
i know your gonna need a clutch pedal..thats about all i can think of..shift linkage....shifter...all the interior parts
will the tranny have all that?
well you neeed the electronics worked out, you need a new gauge cluster.... the shift linkage and shifter interior panels to accomadate
ECU..a dash that doesnt have PRNDD21 on it
Would the shop find all those parts for me? Or do I have to take the time to find those parts as well?
As for the tranny, do trannies usually come with the clutch pedal, shift linkage, shifter? |
The speedometer and ECU I can get it seems. How hard would it be to find a shift linkage, and all that? I can get those at a dealership right?
dealer would have those....check some junk yards too
IF it's 3500 just for the motor, it's definitely not worth dealing with him. keep looking. Now the the new accords also have a 240 HP J-Block with a 6speed tranny, there seems to be more options then just the J32 from the CL type S. Also as time goes on, the CL type S motor/trannies should be popping alittle more frequently.
Also, you should decide what your goal on power is. If you want upwards of 230 or so at the wheels you are going to have to go the forced induction route eventually. In that case you might be better served by just getting a non Type S J32 motor off of EBay. Besides the lower compression ratio which is good for forced induction, it'll also cost several hundred less. |
Okay, so here's what is needed so far:
Motor 6 speed tranny Shifter Shift Linkage Clutch Pedal Slave Cylinder ECU Gauge Cluster What else? |
im guessing the harness will come with the motor or ECU?
You'll need the following...to get you STARTED
engine management computer transmission flywheel complete shifter assembly clutch package clutch master clutch slave clutch hydraulic lines pedal assembly emergency brake assembly and cables engine mounts engine shock subframe axles and stub axle intake plumbing catalyst forward exhaust or Comptech header assembly center console assembly and related minor components money to make changes to the wiring harness as needed time and money to troubleshoot Doing a 5AT to 6MT in a Type-S will set you back in the neighborhood of $7k-10k. Doing a J32 + 6MT swap into a first gen will most definitely cost more than that. |
talk to jimmyrecluse on v6p.net, hes done the swap on his '01 accord (S/C j32 6spd) he spent ~5k +-
Also I don't know how high the 1st gen tach goes, but you'll need a tach that goes to about 8k (redline for the J32 is about 7200 rpm.
I also doubt the J32 headers will bolt to the 1st gen exhaust so you'd need a completely custom downpipe back through the mufflers exhaust |
emergency brake assembly and cables.... engine shock...intake plumbing....catalyst forward exhaust or Comptech header assembly....center console assembly and related minor components.
I don't really think these parts would be needed though. Any other opinions as to whether these parts would be NEEDED to do the swap? |
Totally different. An '01 Accord shares many things with the 2nd Gen CL |
I also doubt the J32 headers will bolt to the 1st gen exhaust so you'd need a completely custom downpipe back through the mufflers exhaust I have the OBX headers and downpipe, that should do it, right? |
I don't really think these parts would be needed though. Any other opinions as to whether these parts would be NEEDED to do the swap? If you don't think these would be needed you won't be able to complete the swap. How is your intake going to bolt up to the J32 :scratch: You'll also need custom work done to the center console to get the shifter to mount up correctly, your headers will not bolt up to the J32 |
:sorry: it would be cheaper to sell your 1st gen and buy a Type-S
You'll also need a new throttle body...
Just wait i'll think of more stuff... |
I'll try and find him, thanks. 5k would be perfect for me, I'd pay that happily. It would leave me with enough money to do the other stuff planned. |
Can you even buy the parts needed for $5k?? Highly doubtful
Just wait i'll think of more stuff... Throttle body dont come with the motor? And I thought the J32 and J30 heads were the same. People have bought the comtech headers from J32's before, so I thought. |
You will also need a machine shop to custom fabricate clutch pedal mounts for your car. Do you even know the dimensions of the 6MT vs your current 4AT? Will the 6MT even fit?
My intake come off a J32, so that would go on right.
I believe the Type-S heads are different, although this is something i'd need to research. |
The intakes for the automatic and the 6 speed are always different. Do you know which J32 your intake was designed for? |
Suppose to be a direct fit from what I have read. I know a current member off of v6.net did the swap, but instead of the whole motor, he just bought the tranny and did it all for about 3k, and plus the cost of a stand alone. I figured I might as well get the motor too. |
I'm sure the swap is possible, with the right amount of money.
Doing a 5AT to 6MT swap in a Type-S has been estimated at $7-10k. Doing a complete motor and transmission (automatic to manual) swap in a 1st gen will most definitely cost more than that. Plus, will it ever run right? If you need a shop to do the swap (you can't do it yourself) this means you'll need that shop to look at the car every time something isn't working correctly. Its going to add up to well over the 5-figure mark once all is said and done. |
I meant to say headers. Yea, I know their heads are different. Are we talking about headers, or heads? |
Do you currently have a 3.0? Or a 2.2 or 2.3? with the manual tranny? |
