Installation prices, how much does stuff cost?
Rollin to GT in da CL
How much do these things usually run to get installed...
Lowering Springs=?
Muffler=?
Full Cat-back=?
Headers=?
Shocks=?
Anything else that might be useful to know, i figured this might be a good thread to sticky.
Lowering Springs=?
Muffler=?
Full Cat-back=?
Headers=?
Shocks=?
Everything besides the springs/struts you should be able to do youself with simple tools. I know some headers for our cars require special modification but other than that its just bolting on.
The problem with springs is that you need a spring compressor so you dont kill yourself with the nut/bolt on the end of the assembly. Also as you may read from previous posts...Acura had the bright idea of installing bolts on the bottom of the spring/strut assembly that rust to the point of fusing with the control arm. So I'd have someone do that and depending on labor it shouldn't run you any more than $100.00 i would think, depending on if you know anyone or not.
hope this helps. and good luck
roomate has a CL too
Re: Installation prices, how much does stuff cost?
Lowering Springs=?
Muffler=?
Full Cat-back=?
Headers=?
Shocks=?
Lowering Springs=?
Muffler=?
Full Cat-back=?
Headers=?
Shocks=?
not sure
I bought magnaflow + mandrel bent 2.25" piping + magnaflow performance resonator + install=$371
headers do it yourself, not that hard
shocks not sure probably 100... if you do springs and shocks probably 120 for both... depends on who you know.
nanos
11-12-2015 08:41 PM
sockr1
10-01-2015 01:31 AM
