ingalls rear camber kit brand new 80$
DOOKS of hazard!!!!
there is no camber adjustment for the backs.....you can shim the back to fix negative camber which means putting in spacers between the strut and the wall it bolts too..........stock there is no camber adj.there are aftermarket LOWER camber adjustments for the rear that are quite expensive....like 150... acurality...if this is what your friend has, 80 is cheap...it looks like a long bar....and the other way is the shim deal...which can range from washers from lowes to real shims designed for that exact setup.....anywhere from 2 bucks to around 30 or 40
nuldabz
09-03-2015 05:49 PM
