Indicator Lights On like an X-MAS tree!!!
97acura22cl420
My check engine light (since 80k) and ABS indicator light (since 110k) have been on consistantly for a while. Both rotors/pads are new front and back (@ 120k). And the engine has been checked, and nothing comes up on the computer. My car runs fine, and brakes well for a car with 145k. My mechanic resets the lights, but they trip, to only go off within a mile of leaving. Anybody else have these lights on in your 2.2, 2.3 1997-1999 CL's??? Is there anyway to turn them off permently or fix the prob short of taking the dash off and removing the actually indicator light?
how handsome I am
so they've taken the little computer into the car and checked for an error code? if the light's turning off then turning back on again something's shooting out an error code...
I know with my car ive got a misfire on my cyl1 that I need to get taken care of.
97acura22cl420
yep. first it said it was the exhaust. Taking I had a leak from the catback, and my muffler was hosed, I fixed it, paid 500.. They turned the light off, I drove off, it turned back on, brought it back for another test, no error codes, nothing...
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
For the abs, I'm told that you can top off your brake fluid, (fill past the fill line) and this usually helps the triggering to stop. Otherwise, check the codes, I just replaced a wheel speed sensor for $300 and it triggered right after I got down the road. Also, if your brakes work fine, and you're not worried about ABS, you can yank the fuse, and the light will go away, or try the brake fluid, I will be trying it this weekend, after I pick my car up 2morrow with it's new tranny
how handsome I am
Originally Posted by SilverCL97
i got that cyl 1 missfire too and i have no idea what the hell to do to fix it..
(Mid-Atlantic)
(Mid-Atlantic)
Thanks, I talked to the regional manager, and he said that he, and a couple of the techs took it on test drives, and said they were "happy with the results"
Can't wait to feel a smooth shift.
how handsome I am
i did that and the cap and rotor and still shows up
ugh.. mechanic also said that there's a SLIM chance it might be a slightly bent valve from a bad downshift 5th -> 2nd...
I, when I was learning how to drive this fucker actually did that once or twice...
(Mid-Atlantic)
(Mid-Atlantic)
97acura22cl420
ut oh.. 5th to 2nd. that shits b-a-n-a-n-a-s. :surrender I have an auto, but shit in my last ride my tranny would've been left on the pavement.
(Mid-Atlantic)
(Mid-Atlantic)
take it easy there Gwen Stefani
by his cubano self
how handsome I am
lol damn... yea it was scary as hell. kept kicking myself in the ass when I did it... must not have been going THAT fast though - I mean, my car's still running.
(Mid-Atlantic)
(Mid-Atlantic)
You probably will need a new clutch
You and i have very similar scenarios.
I replaced the O2 Sensors, EGR Valve and Plugs to the tune of about $800 and still the CEL glows. The "mechanic" (and I use that term loosely right now) believes that there is carbon buildup in my system and it will take another 3-4 hours of labor to clean it out. Any believers?
MY ABS light also was on and they said they inspected my brake system and said it looked excellent....When I added fluid the light went away but comes back after about 20 minutes of driving.
(Mid-Atlantic)
(Mid-Atlantic)
Been a while
Believe it or not Acura has a 120,000 mile recall warranty on the emissions systems on the 97 CL's. I actually took it to McDavid Acura in Dallas Texas and they were awesome. Fixed me right up, said "no charge" and handed me the keys. Thanks!
Too bad I already got ripped off for about $800 from AutoDoc in Houston. Car runs like it was new and I get about 3 extra mpg
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
