idle questions...
idle questions...
Well I've already made posts staying that my car always idles at 1,500rpm whenever i start it nomatter hot or cold or what time of the day it is and goes down to 750 after couple minutes.
I was wondering is it normal for your idle to move down when you turn your steering wheel when u start up the car?
Also is it normal when you turn AC on the idle drops down also...
Im refering to this when im idling at 1,500 when i start the car...
In gear its normal 750.
The idle drops when you turn your wheel or put the AC on because they both run off the belt. Using either your AC or your power steering pump puts a slight load on the belt which is apparently enough to drop the idle.
my RPM goes up when when i turn the steering wheel all the way when i am parked.... is it because of the power steering and that it uses more power so the engine needs to compensate??
DerrickW
11-15-2015 05:52 PM
