I replaced the thermostat now car is not running right…
Over the holiday I replaced the thermostat in my ’98 2.3 CL with 205K miles on it. I was having some funky coolant / heat issues and figured that was a good thing to swap out.
As you know to get access to the thermo housing the intake had to come out and a few sensors near the throttle body have to be un-plugged. I button everything up and start the car and now it runs ROUGH. VERY rough like a cylinder is not firing. It would hold an Idle and when rev-ed to 2 or 3k it does it with hesitation and roughness while at 2-3K.
My 1st thought was I forgot to plug something back in. But I even removed the intake to make sure. My other thought is I could have banged on something where the sparkplug wires go into the distributor. But I unplugged and plugged everything back in…
The car ran fine before I got my hands in there and it’s NEVER acted this way before. What should I be looking for???? BTW, the check engine light is NOT on…
Thanks guys!
Thanks guys!
Originally Posted by spdy0001
You will probably have better luck in the 1st gen forum
Good luck with your problem though
