How to disable the EGR system on a 2.2/2.3
Swaps? $3000 for 50HP? :(
Well after 75 miles on the new engine (with stock ECU), I've had no check engine light from the EGR block I did before I installed the engine.
Heres how I did it.
1st the EGR system is all supplied by cyl #4
You can see in this pic how it the gases get to the EGR valve.
The valve itself (you'll need a new gasket after pulling this off).
Once open the valve feeds all cyl with exhaust gas.
To block the system I used a piece of old head gasket but anything thin and metal will work (aluminum can cut up would also work). You can see the gasket plate is a two piece metal gasket.
To seal everything up, I put Permatex Copper Seal.
You can see it here on the opening that seals the blocking plate to the upper portion of the EGR dist system.
Here it is installed.
You can see since this is downstream from all the EGR valves and solenoids, the system has no way of knowing the exhaust gases arent making it into the engine.
Enjoy.
Heres how I did it.
Enjoy.
The Third Ball
Received 5,103 Likes
I want to know what happened to your 1st engine?
The Third Ball
Just curious if you didnt have to get a new one cause of the turbo
Not trying to say anything. The 500 mile break in is being done without the turbo on.
Why would I sleeve a block, put in crower rods, forged pistons, and buy a stand alone ecu if I was going to stay NA?
cmng 2 a lawschool near u
5. cause you want to
4. you have senile ideas
3.you have no life
2. peer pressure
1. your penis fell off and you need a new way to show masculinity
sorry I am really bored and at work. No disrespect meant, just messing around.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
