how to cut fenderwell?
1 Post
ok, so I dropped my car a while ago and occasionally I'll hear the clunk of the upper contral arm hitting. Also when I got my car alilgned they had a BITCH of a time adjusting the balljoint camber kits because the fender well metal was in teh way.
how do I cut/shave it? just get a big metal file and elbow grease? Dremel?
help?
help?
ENGAGE MY VTEC BABY!!!!!!
it could be the little rubber stud that is on the upper part of the upper arm if you cut part of it off it is to prevent you from bottoming out, if you cut it off to have more play room you will not hit it or should not i say
The movement has started
I grinded mine down and pounded out some parts with a sledge hammer. Make sure to spray whatever bare metal with paint to prevent rusting. I used truck bedliner paint.
1 Post
lol, so you didn't just cut away at teh metel with the dremel or anything?
I would have thought it would just be easier to cut a little circle in teh metal where it hits. Guess not.
mlody
12-04-2019 02:11 PM
DerrickW
11-15-2015 05:52 PM
polish_pat
09-25-2015 12:24 PM
