Help with Tune Up!!!
Old 09-19-2003, 10:30 PM
5th Gear
msalinas1's Avatar
I've got a 98 2.3CL (manual). My car has 100832 miles on it. I do not have the owners manual so i am not sure when the first tune up is needed. Also what type of plugs and wires should i use (does it make a difference). My local parts store wants $54 for a set aof NGK platinum plugs. Are these worth it?
Old 09-20-2003, 07:17 AM
Slooo97CL's Avatar
fuck all that get your timing belt replaced.
Old 09-20-2003, 08:10 AM
A-CL Post Whore w/N2O
dustbuster4's Avatar
Timing belt change is recommended at 90K miles.
I know the 3.0 comes stock with Platinum plugs. They're designed for 100K miles. I'm not sure about performance improvements.
I would recommend a good name brand set of wires that are 8.5mm or larger.
Other recommended 90K mile tune-up items:
Change motor oil and oil filter
replace air cleaner
replace drive belts
replace tranny fluid
replace brake fluid
Old 09-20-2003, 08:33 AM
Stapler's Avatar
they even say somthing about 60k miles in extreme conditions, but i took mine out at 90 and it looked brand spankin new.
Old 09-21-2003, 05:37 PM
Gimmie my points Biatch!
fusionnv's Avatar
Re: Help with Tune Up!!!
Log on to the owners link section on www.acura.com. They have list for all the mileages. Hope this helps.
Old 09-22-2003, 09:19 AM
TEAM BLUR So. CAL
TeamBlurryCL's Avatar
replace air cleaner
replace drive belts
replace brake fluid
yeah i agree with dust. change all your fluids, get new wires and sparkplugs, and change your belt. oh yeah get you injectors cleaned while your at it.
MrHeeltoe
20
02-23-2023 01:54 PM
ExcelerateRep
10-14-2015 08:20 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Help with Tune Up!!!
