HELP needed. Car idle is crazy high.
Old 02-22-2006, 08:57 PM
klepto's Avatar
So i went to go put on my valve cover today. I pulled the spark wires off, the tube that goes to my intake, the tube connected to the throttle body, and the small ground wire on the bottom right. Got a new rubber gasket and put that in as well. Put everything back on and then when I went to start the car...my idle was crazy high, at 2k rpm.
So i shut it off, checked everything, and started it up again, same thing. So i pulled the ecu, backup fuse and disconnected the batt to reset the ecu.
Went to fire it up again and it was still idleing at 2k rpm. I decided to go for a little drive but my rpms would just climb when I drove, I got like 2 feet and my car was just getting louder. I put it in neutral and my rpms were hitting 3k! So i said fuck it, and backed up into my garage.
No check engine light, nothing. WTF is going on? I'm bout to just put my stock one back one, my car is freaking me out
Heres some pics of all the connections.
Old 02-22-2006, 09:06 PM
732xghost's Avatar
valve cover looks really good. isnt that an Accord valve cover??? but what do u usually idle at cuz when my car is warming up its almost at 2k for me??? how long does it take to go down.
Old 02-22-2006, 09:09 PM
klepto's Avatar
yea its an accord valve cover. I usually idle like 1250-1500. Believe me, this isnt normal. Plus when I started to drive the idle climbed up to 3k
Old 02-22-2006, 09:11 PM
732xghost's Avatar
yea thats defentily not normal. does the idle eventually ever go down. not even when its completely warmed up.
Old 02-22-2006, 09:21 PM
mclarenf3387's Avatar
You have a loose vacuum hose somewhere.
Has happened to me before too. Same thing happened.
Old 02-22-2006, 09:25 PM
klepto's Avatar
i left it one for like 2 min and it didnt start to go down. I havent let the car completly warm up yet cause it gets so damn loud, im afraid Im going to wake everyone up or my car is going to explode.
what lines should I check? the only two i d/ced is the one going to the intake tube and then the one going to the throttle body. (pics 4 and 5) Both seem on pretty tight.
Old 02-22-2006, 09:27 PM
crapple94's Avatar
yeah, sounds to me like vacuum hose
Old 02-22-2006, 09:29 PM
You may have knocked one off that you weren't working on and not realized it. Thats what happened to me. The one going to the intake wouldn't affect anything as thats a vent, but the one going to the TB could. Like I said though, its possible you knocked one off accidentally without realizing it.
Old 02-22-2006, 11:00 PM
One custom CL
SupraManAG's Avatar
def a loose vacuum hose. check all the hoses. you should even hear it.
Old 02-22-2006, 11:06 PM
klepto's Avatar
ok I found the stupid fucker, now I cant find where it plugs in to for the life of me
any ideas? I looked all around and find find where this thing is supposed to plug it. It doesnt help that its pitch black outside and my small flashlight keeps dying on me
Old 02-22-2006, 11:10 PM
One custom CL
SupraManAG's Avatar
there is such thing called tomorrow when daylight breaks
leaving it unplugged aint gonna do shit
if the 3k bothers you then put a bolt on the hose and plug it at the right spot tomorrow
Old 02-22-2006, 11:11 PM
One custom CL
SupraManAG's Avatar
and it looks like it connects to the cruise control
on the back
Old 02-22-2006, 11:16 PM
-:-Jenn - O - Cide-:-
strawb3rri3's Avatar
if it's not your hoses. (my civic use to do this, it would even surge up n down) adjust the bolt on your throttle chamber. theres an idler adjuster there.
Chemmech's Avatar
Hold the hose straight up in the air, then let go of it. Where ever it falls is probably gonna be pretty close to where it hooks up. This works with wires too.
Old 02-22-2006, 11:17 PM
One custom CL
SupraManAG's Avatar
Old 02-22-2006, 11:27 PM
klepto's Avatar
I just like to have to peace of mind that my car's ok. I hate just leaving my car like that. Esp because I have to leave for hot import nights tomorrow so my cars gotta run.
Ive been looking for that cruise control connector, I cant find that thing anywhere! can someone point me to where it is.
Old 02-22-2006, 11:29 PM
Insert Sarcasm Here
Smalls's Avatar
even if the advise is incorrect.
Old 02-22-2006, 11:32 PM
wait are you being sarcastic? hah coz i'm serious! this happened to my civic!
Old 02-22-2006, 11:35 PM
klepto's Avatar
i found this, so im guessing its either the one to the cruise control or the intake air resonator check valve. I cant find where my cruise control goes to though
Old 02-22-2006, 11:57 PM
ghost_masterCL's Avatar
as funny as this sounds he's right. Most of these hoses and wires have been bent in the same position for so long they will automatically go there in it's "relaxed" state.
Old 02-23-2006, 12:05 AM
One custom CL
SupraManAG's Avatar
Like I said check on the back of your cruise control. It is located behind the regulator. To make it easier check if there is a vacuum line running there already. If there is check the connectors to the ERG canniester on the right of the engine bay.
My advice is to simply put a bolt on the hose until tomorrow when you actually see.
Old 02-23-2006, 12:06 AM
One custom CL
SupraManAG's Avatar
Also check your evap control canister. Its that large black bottle looking thing under your TSP sensor.
Old 02-23-2006, 12:15 AM
One custom CL
SupraManAG's Avatar
The pictures point to the cruise control. If you notice in your pics there are 2 lines coming from the steel connectors. One of the hoses from it is your unidentified and the other connects to your evap control canister. A hose as long as the one you have only connects to the cruise control. It is a bitch to get to it because its in the back on the regulator.
Goodluck
Old 02-23-2006, 12:18 AM
First EVER K24 Turbo CL
starboy2nv's Avatar
no man that loose hose goes to your intake...
Old 02-23-2006, 01:43 AM
Chemmech's Avatar
Believe me, I learned this from some old mechanic when I was in the Air Force, it works believe it or not :p . This is the methode I always use, since I'm too lazy to label stuff when I take it off.
Old 02-23-2006, 02:26 AM
Racer510dude's Avatar
I suggest you put your original valve cover back on and see if it still idle poorly.
Old 02-23-2006, 03:07 PM
732xghost's Avatar
lol its defenitly the hose. i think that is his stock valve cover anyways, he just painted it.
Old 02-23-2006, 03:58 PM
One custom CL
SupraManAG's Avatar
He experiences gains in his rpm meaning the hose is sucking. If the hose were to be placed in his intake it would still have a constant flow of air running thru it hence the problem would persist. It possible that the hose would be connected to the IAR control selenoid valve then the intake. The hose looks too long for it to go to the IAR.
Whats the status of the situation.
Old 02-23-2006, 06:17 PM
klepto's Avatar
well ok. Now my car is possesed. I checked behind the cruise control unit and couldnt find anything that the hose would connect to. I checked where the other hose goes to (red one) and that one is connected to this black cylinder thing right under/behind the cruise control. So where does the other one (blue) go to? Can someone trace it and find out for me? Its the bottom one of the two metal hoses.
Anyways so I tried to take my car out for a spin and I found out that its DRIVING ITSELF. Its like my car is in constant cruise control. I can take my foot off the gas and the car still goes at a constant speed though. I tried turning on/off the cruise control and none of it works. So something is super whack with the cruise control.
Sucky thing is that I have to drive home (80miles) tonight. At least my car runs, but whenever im stopped or in neutral, the thing is revving at 3k.
Old 02-23-2006, 07:08 PM
One custom CL
SupraManAG's Avatar
dude you owe me big time for going out at night and getting my hands dirty like that
ok here i the deal
there are 2 vacuum connectors going in the cruise control and on going out.
The first one is located on top which im pretty sure you have already connected but if not here is the pic.
Right below that but a bitch to get to is the second connector. There is a vacuum line going in and another going out os the canister. Like I said its very hard to get to.
So you an idea where the position is just follow the finger.
Goodluck
Old 02-23-2006, 07:09 PM
klepto's Avatar
GOD im such an idiot. When I put on my new valve cover I clipped on the throttle body cable too tight. So thats what was giving my car that extra gas
I uncliped the cable and let it sit loose and everything was FINE. GOD damn, what a scare, I was about to drive home like that too. So relieved it wasnt anything serious.
Old 02-23-2006, 07:48 PM
The new ride
Mulk's Avatar
lol noob
j/k but what about the hose? did you find where it goes?
Old 02-23-2006, 08:03 PM
klepto's Avatar
im not sure. Im thinking it hooks up to the stock intake and isnt needed if you go aftermarket i just plugged it up and left it there
Old 02-23-2006, 11:28 PM
Peace, Love & Acura
ajtcl's Avatar
What crazyness. Loose hoses, clipped throttle cables, WTF?
Old 02-23-2006, 11:38 PM
CleanCL's Avatar
you guys are nuts. i can't believe i read through this whole thing. it reminds me of that movie hostel where your expecting something scary and then the end is just stupid and funny.
Old 02-23-2006, 11:50 PM
Upgrade
Jonniwatts's Avatar
lol, that movie was kinda funny, but i'm glad he did that to that punk ass wanna be doctor, even though it was a movie
Old 02-24-2006, 12:23 AM
97 2.2cL black
chuckz's Avatar
justin, you crack me up. lol.
Old 02-24-2006, 02:07 AM
Im No Superman
h2o-pr00f's Avatar
gluck @ HIN mang
Old 02-24-2006, 03:12 AM
how handsome I am
agranado's Avatar
OMGZ WE JUST FOUND THIS IN HIS EBAY
IT was eating through his cables and hoses, and was going for the painted valve cover next!
Old 02-24-2006, 03:48 AM
SSM Accord V6 6 Spd
EPS CL's Avatar
OMG, man. WTF. That thing just scared the shit out of me.
And congrats on getting the car fixed. Valve cover looks good
Quick Reply: HELP needed. Car idle is crazy high.
