Help with JACK STANDS PLEASE!!!
You know him right?
Hey guys, I'm finally going to put my summer rims on!!!! I can't wait, but I want to repaint the calipers. The last time I painted them, I did 1 at a time.
Would it be safe to jack the car up from both sides (ie whole front end) with 2 jacks?? or is there anywhere I can jack it up and use JACK STANDS? Please help asap
I wouldn't put the whole front up on 2 jacks if you can avoid it - If you have stands just jack one side up, put the stand under it (on the frame or something solid) and then do the other side the smae way. Don't forget that e-brake...
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
as long as you don't get under the car I think two jacks will be fine. But jackstands are so cheap you might as well go buy some.
A-CL Post Whore w/N2O
I would NOT recommend getting under a car that was only held up with jacks. You'll probably be ok, but if not, the consequences are too much! :thumbsdn:
Get the jack stands. They're not that expensive.
When I change my tires, I only jack up one corner of the car at a time. If you can't get jack stands, do this.
You know him right?
i have jack stands, but I dont' know how to put them under when I jack the car up because there is only 1 (offical) support place to jack the car up???
ooooo, there is a hook in the front that you can jack it up w/. Do that and then slip the stands under on each side. Same thing w/ the back. THere is a hook back there too.
My Home Planet
How big is your jack????
I have a 2 1/2 ton jack. When I did my shock/springs all I needed was 1 jack to lift the entire front or back ends of the car. The jack gets place in the front/rear of the car, dead center. There is a cross bar for the frame that is fine to use for jacking up the vehicle. I wouldn't do that though without at least a 2 ton jack. Anyting less and your better off using at least one jack and one jackstand.
navtool.com
31
11-16-2015 08:30 PM
SUPRMN84
10-07-2015 09:46 PM
navtool.com
09-25-2015 05:15 PM
