help gas problem
Old 09-17-2002 | 03:40 PM
n2civicsi's Avatar
3rd Gear
help gas problem
Ok i have a 99 cl and recently its been acting up. before it would just happen once in a while. the car will jump and then wont go any more, it just stay under 1700rpm and go 20mile only. now after i change the gas filter and put some octane shit in the gas tang. it dont do it anymore but the rpm is low when i'm driving and i have to press hard on the gas to accerate and rpm to kick in. dont know if its normal or not but 2000 rpm and 65mile. Was wonder if anybody can help or ran into this problem thanks
Old 09-17-2002 | 05:26 PM
gjr2001's Avatar
An Official Cl Whore
I would take it you have a 3.0? If it is still under warranty have it looked at asap. sounds like you may have a fuel injector problem. What is your idle speed?
Old 09-17-2002 | 06:05 PM
n2civicsi's Avatar
3rd Gear
idle speed
it a little under 1k rpm , so change the injectors, and it not under warranty any more thanks
Old 09-17-2002 | 07:52 PM
gjr2001's Avatar
I was thinking, check the spark plugs to see if they need replaced, if not it could also be the ignition timing is off.
Old 09-17-2002 | 08:06 PM
n2civicsi's Avatar
3rd Gear
is there any way to test out the injector to see if they are bad also, cuz they cost 103 per injector dam they cost a lot
OculiAquilae
11-19-2018 03:24 PM
Powder Monkey
2G CL Problems & Fixes
09-09-2018 01:55 AM
SpraykwoN
ILX
09-24-2015 06:20 PM
Mike Bertram
09-10-2015 10:27 AM
ninersfgiantsfan
09-09-2015 02:14 PM
