Hell yes, finally found the engine...
Originally Posted by Veritas
seems like a good find.
i may go that route this winter. i got a family friend who says he can swap my shit to manual no prob so ill see how much hes talking. if its around $500 i may just do that but if not might as well just swap everything.
you should check out this site. its got all the JDM engines honda makes, and tells you the hp/tq it makes and also the compression ratio. you can buy from them also. Good luck!
this is the best lude engine i think. but compresion ratio is higher.
Cars: JDM 97-01 Prelude Type-S
Mileage: 10,000-20,000 miles
2157cc (DOHC VTEC)
Horsepower: 223hp@7200rpm
Torque: 163lbs-ft@6500rpm
Compression: 11.0:1
Bore: 87mm
Stroke: 90.7mm
OBD: 2
Genuine Japan-import Only
$3,699.00USD
Cars: JDM 97-01 Prelude VTEC
2157cc (DOHC VTEC)
Horsepower: 202hp@6800rpm
Torque: 161lbs-ft@5500rpm
Compression: 10.6:1
Bore: 87mm
Stroke: 90.7mm
OBD: 2
Redline: 8200rpm
$2,299.00USD
Cars: JDM 92-96 Prelude VTEC
Mileage: 28,000-45,000 miles
2157cc (DOHC VTEC)
Horsepower: 200hp@6800rpm
Compression: 10.6:1
Bore: 87mm
Stroke: 90.7mm
OBD: 1
Redline: 8200rpm
July Blowout Price: $2400USD shipped!
Accord Euro R engine
Cars: JDM 97-01 Accord Euro-R
1997cc (DOHC)
Horsepower: 200hp@7200rpm
Torque: N/A
Compression: 11.0:1
Bore: N/A
Stroke: N/A
OBD: 2
$3,000.00USD
http://www.totaljdm.com/index.cfm/fu...dm_engines.htm
2157cc (DOHC VTEC)
Compression: 11.0:1
Bore: 87mm
Stroke: 90.7mm
OBD: 2
$3,699.00USD
2157cc (DOHC VTEC)
Compression: 10.6:1
Bore: 87mm
Stroke: 90.7mm
OBD: 2
Redline: 8200rpm
$2,299.00USD
2157cc (DOHC VTEC)
Compression: 10.6:1
Bore: 87mm
Stroke: 90.7mm
OBD: 1
Redline: 8200rpm
1997cc (DOHC)
Torque: N/A
Compression: 11.0:1
Bore: N/A
Stroke: N/A
OBD: 2
$3,000.00USD
Originally Posted by Gorm
Hey, does it go into 3.0 or 2.2?
And, really, anybody changed theys automatic into manual on 3.0?
yeh, imma get LSD for the additional 300. some peeps advised me too cuz i'm planning on adding a lot of whp and i heard that the auto tranny is shit when it comes to high whp, so imma go with manual w/lsd
