Headlights
We dont love these hoes
Headlights
Im sure this question has also been asked before, im just wondering how to adjust my headlights, theyre aimed way off, one of them is aiming to the right and another is just way up. any help would be great
acura-cl.com OG
if you have an owners manual, check it out in there. I haven't done it in a while, but if my memory serves me, there are 2 holes above each headlight that you stick a screwdriver in and turn to adjust. Park (level) infront of a garage or wall and aim the headlights. It is VERY easy and will take no longer than 10 min per headlight, if they are WAY off!
I tried to adjust mine tonight per the instructions in the manual, using the level guage, but I had one problem:
when I did that, the lowbeams were offcenter ( the driver's side was really close to the ground with the car 15-20 feet away ) but the high beams were dead on.
If I adjusted them per other means, ie, using the sheet of paper and the garage door the high beams would be way off ( the driver's side would be way above the passenger's side )
any ideas? I thought the driver's side was supposed to be a little lower, but how much lower?
AmplifiedDetails
09-24-2015 02:55 PM
