Headlight question
Old 06-11-2004 | 12:52 AM
9D7Ack's Avatar
1997 Acura 3.0CL
Headlight question
i just got the clear bumper lights for my car and when you look at them and the headlights you could tell the stock headlights are more "foggy" than the new crystal clear bumper lights.....esp the parking light on the side of the headlight....is there a new peice or headlight that i can buy so the match and it looks a lil bit better?....its not a big deal i just thnk it would look better if the were both cystal clear
Old 06-11-2004 | 01:04 AM
dragon084's Avatar
1999 CL3.0
thats y u stik w/ ambers , wheres c-mack?
Old 06-11-2004 | 09:40 AM
joeshmoe's Avatar
My Home Planet
Nothing fits perfectly, but headlight conversions have been done with some modifications.
Old 06-11-2004 | 10:23 AM
swbball28's Avatar
im also looking for stock headlights that are in good condition (not foggy). Anyone know where i might be able to find some?
Old 06-11-2004 | 10:34 AM
Skittlebrau's Avatar
How many highway miles are on your car? The headlights look foggy probably because of years of sandblasting at highway speeds. I didn't realize how bad mine were until I got in an accident and had to have the passenger headlight replaced. The difference is rediculous. The older one with 150K on it barely allow light to shine through it. Time to get a new one to match, I guess. You can get one here:
http://acuraautomotiveparts.org/acur...prddisplay.jsp
Old 06-11-2004 | 10:52 AM
creationCL's Avatar
CLanty-eyed
last weekend, i took some plastic polisher that acura gave me a few years ago when i got the car and sprayed it on the headlights. after a few minutes, i buffed it off, and WAS THERE A BIG DIFFERENCE. the chrome inside actually LOOKED like chrome on the outside! it hurt my eyes when the sun reflected off of it i went ahead and did the clear bumper lenses and taillights too, looks absolutely crystal clear. give that a try, shouldnt be more than a few bucks at your local shop.
Old 06-11-2004 | 12:45 PM
fusionnv's Avatar
Gimmie my points Biatch!
Yeah using a plastic polish and then follow with a plastic safe wax will do wonders for the headlights.
Old 06-11-2004 | 01:28 PM
ju5tchi11in's Avatar
roomate has a CL too
others have resurfaced the headlights wet sanding using higher grit sand paper then working to finer paper and buffing. search for this one someone posted directions about resurfacing... basically a new headlight after ur through.
Old 06-11-2004 | 02:15 PM
fusionnv's Avatar
I recommend using a polish first (only takes a min). Some cases you might not need to sand paper the headlights. I believe you should try to use the material that takes off the least first.
Old 06-11-2004 | 02:21 PM
Chinisimo's Avatar
what brand is the plastic polisher and where can you get them? i got a bottle but that shit get cloudy again after a couple weeks. how long does this one last?
Old 06-11-2004 | 02:46 PM
probably same amount of time... the problem is the light from ur headlight is getting refracted because of all the small chips and dents on the outside of the headlight. The polish might clean off the outside but the chips and dents remain. but polish first it might work.
Old 06-11-2004 | 03:00 PM
fusionnv's Avatar
It is either that or the polish u got has fillers in it. Where it covered up the chips and scratches and then when they washed off they exposed the suckers again. Hmm I think to think of one that doesn't have one and is easy to find in stores. I would say meguilars but you should call them and ask. They have a number and are able to answer u questions really fast.
Old 06-12-2004 | 01:41 AM
athlonxp's Avatar
Basically in working at Advance, there's a product by Meguiars called Plastic Lens Cleaner. It's a small light blue or white bottle that's almost seven dollars. Customers claim that it does wonders. It actually clears up the "yellowish residue" on the headlights.
But yeah I posted the how to on the sanding/buffing technique. That is mainly for those who have really bad discoloration with deep grooved dents and scratches like I did.
Anyways good luck.
-James
Old 06-12-2004 | 09:36 AM
swbball28's Avatar
how can i take out the water that my headlights have inside? And how can i prevent future water from getting inside.
Old 06-12-2004 | 11:07 AM
18anatak's Avatar
Yea i used to polish and wet sand my old headlights all the time. The Meguair's product athlon mentioned is good stuff. But eventually i got tired of it, and just bought new headlights.
Old 06-12-2004 | 11:56 AM
wilp99's Avatar
use never-dull polish, or mothers alluminum polish. ive tried both of these on my eagle talon and they came out about 90% better.
oh yea u have to scrub for like 5 min each light. then use a car wax on them. theyll look fly.
Old 06-12-2004 | 04:49 PM
swbball28's Avatar
will i need to apply the plastic polish with a buffer, or will it work by hand?
BoricuaTL
04-08-2016 02:08 PM
pistacio
09-26-2015 10:45 AM
eastcoastguy
09-24-2015 03:07 PM
datadr
09-12-2015 10:12 PM
prox
5G TLX Problems & Fixes
09-01-2015 03:03 AM
