Having an acceleration issue
I have no idea whats goin on, but it seems like if i come around a corner and gun it, it bogs down then it almost feels like i have nitrous. The engine just kicks in and goes. It doesnt really bog, it just does not go anywhere.
Would a dirty airfilter be the culprit? I have no clue. |
slipping tranny :dunno:
5 speed
could it be a clutch issue?
Originally Posted by SwervinCL
5 speed
edit: maybe a fuel filter or fuel pump. |
If it were that wouldnt it be all the time rather than just around a corner?
Im clueless. |
not necessarily. (sp?) Since you are giving it more gas after a turn, its suffocating itself more and hesitating more.
what happens if you gun it while going straight?
Its fine. Beat a neon this morning on the way to work with no problems (other than lack of traction)
lol @ you having to spank a Neon to know that your CL was ok.. Poor Neon.
well no matter what u should beat a neon. I beat a 90 camaro V8
I HAD THE EXACT same issue !!!!!!!! add more oil to your engine !!! or get an oil change. THAT is the issue ill bet money on it !!!
I had kind of had a similar problem. I was going through the canyons by my house, on a turn i down shifted going into the turn and then when all of a sudden it seemed that my rev limit kicked in. but i was only at 4000 rpm, and had to immediately shift. I changed my oil the next day and haven't had that problem again.
Poor Neon? Arnt they poor from the factory?
