handling help
handling help
After my myriad of mystery mods is installed, I'm gonna need for my car to handle well. I just wanted to make sure that my list of parts that i did a search on is correct and that this will all help to stabilize my handling.
Energy Suspension Motor Mounts
Energy Suspension Rubber Bushings
Coilovers
cusco or tanabe sway bars
What am i missing? I know theres a few other things i can add. The only thing i have on this list so far is coilovers. Help me out guys!
Coilovers
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Tires are a must, you have a camber kit chris? I'd highly recommend a cusco front lower strut brace. Really ties the steering together. Also front and rear strut bars, rear makes a big difference I hear
I dont have a camber kit on the car, will that matter chris? Should i get one to go along with the lower strut brace and strut bars?
Also Cocoa, with all strut bars and braces, how do i stiffen the rear more than the front?
Matt can u put a pic of the tie n c-pillar bars? Im unfamiliar with the C pillar bars.
(Mid-Atlantic)
(Mid-Atlantic)
Sheeit I could get one built for half of that
ok so, so far i have :
Motor Mounts
Bushings
Sway bars
front and rear strut bars (same as sways?)
front lower strut brace (is there a rear one too?)
front and rear lower tie bars
c pillar bar
camber kit
Anything else or any links to any of these products? Any specific brands for each that you guys recommend?
Motor Mounts
Bushings
Sway bars
c pillar bar
camber kit
(Mid-Atlantic)
(Mid-Atlantic)
Polyurethayne Motor Mount Inserts
Polyurethayne Bushing master kit
Front and Rear Sway bars
front and rear upper strut bars
front lower strut brace, and rear lower tie bar
Floor bar
Front and Rear camber kit
Engine torque damper
Floor bar
(Mid-Atlantic)
(Mid-Atlantic)
Fixed
Originally Posted by Palayah8ta
Gottamn i got something right!!
i figured a helical lsd would help with traction
(Mid-Atlantic)
(Mid-Atlantic)
Cheap bastard
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
