Gude Camshafts
Gude Camshafts
i am considering buying a new camshaft , cam gear, port/polish vavle spr, retainers. the gude camshaft said stronger power from 2000 rpm to redline , and changing the power band to 5000-7200 rpm which would be increasing our rev limit so we can do more damage. when ever i race someone for instance a gsr i stay with them off the line but then i would shift at 6300 rpm which sucks so why not
Moderator Alumnus
im not a big fan of gude at all.
some people from more technically oriented forums are working on getting a F22 cam made. you can actually use the prelude valve springs and B series retainers. that setup should be better for swinging a fat cam around. plus, you can always convert down to OBDI and use a P28 ecu (re-tune of course). there is plenty of stuff for F-series motors.... you just have to know where to look. i just for fed up with mine.
WhyteLegend
11-27-2007 10:03 AM
