Got a beat question.
For you guys with subs, is there an existing hole to run the power wire from the battery through to the cabin or did you drill?
Just hooked up the subs two nights ago in my garage and ran the pwr wire from the battery to the fender through the door (where the top of the fender meets the door = ghetto rigged) temporarily for a test thump.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
You don't have to drill, right above the fuse box and the pedals on the left side, there is a rubber stopper, with a bundle of wires running through it. Just pop that out, run your wire through, and stuff it back, just like new.
make sure if you do this, you put some black tape around the wire so it doesent get cut by the metal..
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Mulk
the rubber grommet he's talking about has some extra space around the bundle of wires, i just poked a hole in that and pushed it through instead of actually taking the grommet out
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
