g35 projectors going in my cl
ftl. florida in da house
im putting these projectors in my cl. i wired s2000 ballast to these projectors. this is going to be a task but ineed two headlights to do this job. i have two more g35 headlights im willing to trade if somone has two extra cl headlights.. let me know....... ![](http://i197.photobucket.com/albums/aa204/scoopin/DSCF0410.jpg)
![](http://i197.photobucket.com/albums/aa204/scoopin/DSCF0409.jpg)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Nakamichi
Looks like bi-xenon. How's the fitting? I wanted to put some TLs (bi-xenon) in, but they are massive.
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
thier brite bitches. i wonder if i can hook the steering to the lights they turn when you turn i dont think thier bi xenon the red wires are for steering
~[ô¿ô]~
Oh they are AFS. I have not heard of any success stories at hidplanet of getting the AFS feature working in a car that did not have it . But if you can do it, send over the info.
(Mid-Atlantic)
(Mid-Atlantic)
the sensors should be easy to install on the rack. since im a electronics tech making a board with a neg to pos swing to move the silenoid should be easy. this should be interesting ill post more on this as i go............
~[ô¿ô]~
Yeah I would think so. You also need to grab the speed either from the ECU, VS or Shaft Speed Sensor. Since you have to look further down the curve at higher speeds, the projector would have to pivot more than at low speeds. Or just have the projector go into full pivot upon a steering turn detection.
How about using the existing ABS wheel sensor? When you turn right the left wheel sensor should emit more pulses, then you can pivot your right projector. Vice-versa for the opposite.
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by G22_Powered_YA1
bi-zenon after all
good luck with those
I'm not familiar with the g35 projectors, but I think they're middle of the line performers. Since they're bixenons, they seem like they may actually be the same as the FX projectors, which are OK projectors in stock form and have good width but the foreground intensity isn't too great. However if you can get a set of crystal clear lenses such as the TSX projectors, you can get a crapload of sharpness and color out of those things. If I'm correct, those things have fresnel lined lenses.
(Mid-Atlantic)
(Mid-Atlantic)
ok i stand corected the red wires are for half light and full light
say: zouts
(Mid-Atlantic)
(Mid-Atlantic)
i have a lot of cutting and fab to do this is not easy but not imposible.............
ill let you know im going to order new headlights. (mutch mutch muuula) im going to test using my old headlight. ill be making pics of progress.....
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by LDH
Has anyone ever fit a bi-xenon projector in the CL, like TL projectors for example? Or is the tsx a close fit as is?
The TSX is perfect fit, but it's not bi-xenon. Both 97acura3.0CL and VXCL fit bixenons into CL headlights, VXCL also did Outlaw's retro which I believe was bixenon as well, they always used BMW bi-xenon projectors. No one has done TL projectors in a CL that I know of, the last 2 members on here that did it including myself were both TSX.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
(Mid-Atlantic)
(Mid-Atlantic)
I wanted to do the TL bixenon, tsx, or s2000 (if I can find a set at a reasonable price). I'll probably do tsx since I still have a couple pairs of projectors left. How perfect of a fit is the tsx? I don't have a CL yet, so I can't take the headlights apart to test fit. How hard was it to make your custom shroud? I'm trying to keep the headlights all reflective without blackhousing. All my other retrofits are blackhoused to make it easier to hide things. ![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Check out my pics here.
https://acurazine.com/forums/showthread.php?t=190428
The shroud was simple I used a shroud from another car and just trimmed it to fit, painted the shroud black. I kept mine all reflective, and nixed the blackhousing cuz it would have been too raccoon eyes for me.
I saw your thread about the retrofit while doing research. I meant I want the part you put CF in to have a reflective shroud. I'm guessing the easiest way to do that would be to use bmw E46 "xenon" shrouds. I did one of my of my retrofit with a similar style shroud as yours. I used sheet metal painted black with a piping reducer from ace hardware.
(Mid-Atlantic)
(Mid-Atlantic)
im getting fx projectors. my frend works for infinty dealership they replace the headlights all the time so he allways gets extra i wonder if they will fit better in the cl headlight
