Fusible Link
Bagel Bomber
Fusible Link
Anyone know where the alternator fusible link(s) are? I'm still trying to diagnose my blinker problem with the lights dimming so much with blinker usage.
Bagel Bomber
Cleaned EGR Port - Still getting P1491
As the title states, about a month ago, i drilled out the intake manifold and cleaned it, reset the ECU. The CEL for this code comes on about 500-600 miles after the ecu is reset......
Let the creative juices flow: thoughts/comments/questions/suggestions
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by TexasHonda
You need a shop manual, then you won't have to beg for info.
Bagel Bomber
i have it too, mine doesn't show pictures though, were you able to find any fusible links, if so, hit ALT+Print screen and host the picture.
Bagel Bomber
I don't think there is a fusible link. There is a master fuse in the underhood fuse panel. You need a shop manual, then you won't have to beg for info.
good luck
good luck
If thats the case about the fusible link, do you have any more ideas why my lights dim so much when i use my blinkers. This happened before the system install, I have a new alternator from acura, and battery has been tested fine. ideas??
rcs86
08-02-2016 06:52 PM
lanechanger
10-13-2015 10:56 AM
