Front Bumper
ahnyoung!
Front Bumper
I was wondering how to take off the front bumbper and i seem to not get it off
it's pretty sad yea. . . well i'm trying to take it off so i can black house my headlights but taking the bumbper is wierd. . .i took off the bolts but when i tried to take it off. . . i found out theres bolts under the lights. . how did you guys take those off??
i tried kinda of hard take the headlights of both then the plastic bolts and there are more bolts i dont know where thats as far as i got let me know if u get farther good luck
check out KLepTo's webpage. . .http://home.comcast.net/~daklepto/diy.htm
it'll show you how to do it
ENGAGE MY VTEC BABY!!!!!!
it is not on his site
here i go.........................
get a 12mm socket and 2 extension wands, and a srewdriver, stubby and long screwdriver
there are 1 screw on each side that hold the lender liner to the bumper towards the bottom some have it towards the top, then there should be a hole on the inside of the lower grill next to the inside part of the turn signal, take a screw driver and unscrew this screw
pop out the turn signals, look inside and up to your top left inside if you are on the driver side there is a bolt, use the 2 wands and the 12mm socket and undo this bolt, then go to the inside of the grill on the other side of that screw there is another 12mm bolt, it will be on the other side of the plate next to the first bolt, take off the other one, repeat to the other side
when this is down it will be loose, lift up and pull away, this is the easiest part, when you put it back on it will be a little tricky to align it but put it the same way you got it off
presto your bumper is off
hope this helps
Joe
hope this helps
Joe
ahnyoung!
WHOLLY FUCK THAT IS SOO MUCH WORK~!! hahaha aiite i'll start on it 2morrow
and see if it works
i rather do this on a civic -_-'' 3 minutes of work LOL~!!!
thanks for tip Joe . . hope it works
and see if it works
ahnyoung!
How do you take off those pins under your headlight? cause it seems you can't take off the bumper without those off -_-'' kinda confused -_-''
Oakes
Wash & Wax
10-12-2015 11:17 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
robowarrio
09-01-2015 09:25 PM
