Fog Light Problems
Fog Light Problems
I just receieced a set of H3 Eurolite lights. I have a 1997 cl which came with stock fog lights. I wanted to change out the lights that came with the fog lights originally. No matter what i did i could not get them to work. Can anyone help me out?
My Home Planet
Make sure the wire that is attached to the h3 bulb makes clean contact with the connector on the bulb assembly.
The lights worked before you changed the bulbs right? Just checking.
A-CL Post Whore w/N2O
I can't make any suggestions without knowing exactly what you did.
However, here's some diagrams on places you can check for problems.
http://public.fotki.com/dustbuster4/installingwiring/
EDIT: Did you make sure that terminal of the wire coming off of the bulb was pushed way down into the holder socket of the foglight assembly (Step 2).
Thanks it is very informational but unfortunately the only thing there i didnt do correctly was use a genuine honda bulb. Is there any way to test out the bulb itself?
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
