Factory Alarm goes off on its own!!
Twice in the past month (that I know of) my car alarm has been going off randomly. I'm not really interested in figuring out why - anyone know how I can simply disable the alarm? I'm thinking of just disconnecting the siren - if the car knows it isn't connected, I'll short out the harness for it.
Any ideas?
Any ideas?
Nice, I found this guide:
https://acurazine.com/forums/showthr...=remove+bumper
Unfortunately, the Service Manual says bumper removal is step #1 to disconnecting the siren
This post:
https://acurazine.com/forums/showpos...3&postcount=35
Seems to imply there are no problems just disconnecting the siren. From them on the alarm would be 'visual' only.
This post:
yeah mine has been doing it too, I figure it might be the actuators messing up since they have been and an "unauthorized" unlock would trigger the system......... or it coulld be my remote starter getting set off in my pocket and having the ignition sensor tripped
CLeanest in its CLass
This post:
This post:
no no no you dont need to remove the bumper!! if you dont wanna fix it the right way you can get to the siren by getting up underneath the car, the siren is on the lower right side of the firewall. you should be able to get at the wires there, though id def. put some tape or something so they dont short out the rest of the system. Or you can disconnect the alarm from underneath the pass seat where the control unit is (it should be the brown wire) good luck
I did try the continuity test on the hood sensor since that was mentioned as being problematic in a couple other posts - it seems to be ALWAYS open - I could never get continuitity. Luckily open means hood closed, so disconnecting the switch won't trip the alarm.
