Escort Passport 8500 X50 hardwire
I just purchased an Escport Passport 8500 radar detector. I had a few questions about it that I hope you guys with experience can help me with.
I have a 1998 Acura CL 3.0 (all stock, for now). I'm a knowledgable person with techinical stuff (a/v, wirings, etc). I've never gone into my car to wire anything, but I want to try if I can.
1. How do I pass the power wire down from my radar dectector to my fuse box? (Which fuse box should I use?)
2. I have a small display add on which will mount somewhere on my dashboard. Any suggestions for where to mount it, with what, and how to run the wires best? Smart Wire
I have an extra little panel to the right of my digital clock. If that would be a good option..
3. My car has the factory issue tinting, nothing extra added. Whats the best mounting location ? Under the rearview (with my EZPASS) or low to the dashboard?
you can pick any fuse but i would wire it to a 30 or 25 amp fuse, that should be plenty if you want to be on the safe side, you can gget a fuse wire that have a wire with a fuse holder that you can put your own fuses in for things, i have one for my interior neons, and then run the wire to your location and wire up, grounding you can ground anywhere that have a bolt/nut
Originally Posted by shmookles
i want to hardwire it!
Find a fuse that turns on and off with the ignition that way it is not always on. I tried wiring mine to the above lights and the only thing about that is that it was always on. No biggie, but it could drain the battery in time. I HATE wires so i have my radar detector right next to my rearview mirror. The wire runs down the headliner and then down the front left pillar down to my fuse box. Ill take a picture tonight and post it. Its really easy to do. I didnt want it sitting right in the middle of my window for all to see. Plus i have aglare strip on my front window so you cant see it from outside the car. You dont even notice it on the inside unless you hear it beap....
As to where to mount the aux display. i would mount it inbetween my steering wheel and my gauges.
i know this is bringing this thead back from the dead...........but i picked up a new x50 today. I am planning on buying the hardwire kit as well. I have a 98 CL. Does anyone know if the blank where the fog light switch would go is big enough to dremmel out so the smartdisplay can fit in it??
Originally Posted by ajtcl
I wouldn't do that if you ever intend on selling it.
But if you want to modifiy it, you can use the dremel. With a dremel, you can do anything.
Originally Posted by 972xghost
why are you hardwiring it, you can just plug it into your ciggerette lighter???
well thats good, so am i, but i have the same radar detector and it looks fine in my interior, i hardly notice its there. the detector was expensive enough i wouldnt feel like spending more money on something that works the same/
i realize that, but it doesnt seem worth the trouble.
Just my
Originally Posted by SwervinCL
Can you read?
Originally Posted by ajbent86
i sure can, but nobody has spoken up as to if it is too big or anything...........i dont have the hardwire kit yet, so i have no clue as to what the size of the smartdisplay is......
well my last statement regarding this thread is, are u just gonna use the radar detector for your car, will it ever be in someone else or use it if your driving someone elses car. the main reason im keeping the chord is because i drive cars all the time for my job and use it in my friends cars and things like that. just something to think about.
ok I have the same thing on my car with the hardwire remote.
1. I ran mine through the side a-pillar, it just pulls off
2. I mounted my remote on my gauge pod, to the right of my tachometer.
3. My window's are tinted to 35%. and I have it in my upper left hand corner about eye level on my windshield!
The remoteisn't that big it's about 1/2" tall x 1" wide x 3/4" Deep
I have my v1 harwired and I also have the concealed display. I have the main unit mounted right next to my rearview, the wire goes up, hidded btwn my windshield and headliner, goes down through the A-pillar, and then down to the fuse box. The concealed unit it mounted right on top of my steering colum, the wires for that are hidden behind the plastic covering under the steering wheel down to the fuse box.
Exactly how mine is. But not the v1 part. Justin, can the v1 still pick up behind you mounted in that location?
and didnt have time to take teh v1 down and the cop couldnt see it, wheeww.
yea, it isnt obstructed, it still has a clear view front and back, I just mounted it as close to rear view as I could. You cant really see it from teh drivers side which is good because one time I got pulled over for no front plate
and didnt have time to take teh v1 down and the cop couldnt see it, wheeww.is it illegal in cali?? I didnt think so.
