Engine water leak
Engine water leak
my car overheated the other day . i replaced the radiator and everything was cool but, i noticed the engine was leaking water from the back there's ahole in the engine block under 2 the right of intake manifold. any ideas??
if a car over heats enough it will pop out a freeze plug. or could be a blown head gasket.
what ever you do dont put the stop leak stuff in the radiator. looks like pepper. its really bad for the head ports. glogs them up and wont allow coolant flow.
Originally Posted by wilp99
is it a machined hole for a screw. or a hole like something busted thru.
looks like machined hole. but water leaks out of it.????
