Engine swapping
Tristate ViP Crew
If you are talking about a 2.2 or 2.3 the fastest way you can go is the JDM H22A that puts out a stock 220hp. From there you can turbo it up or add your basic add ons to it.
CL 4 LYFE
1 Post
Originally Posted by SanJoseRoller
since we are on this topic does anyone know if a LS/Vtec motor would fit into the engine bay?
Flap.
use the search button, stop post whoring...
its all been done before there are plenty of h22 swaps.. yes you can do auto -> manual.. no dont use a teg engine.... price depends on the shop and where you buy the engine
2600lb CL
Originally Posted by lnsyone
Why would you want to do that? Why put a smaller motor inside your car which already weighs a good 1200 pounds heavier than a Civic or an Integra? Aside from that, it would probably take a good ammount of fabrication to fit it inside the engine bay. With all that time and money you had spent on an LS/V swap, you could have a built f22 or h22 that pushes 250+ whp.
I'd pick a CRV block with a B16/B18 head. Low compression, high boost! My friend is doing that swap into his teggy.
if ur doin the whole motor swap then all u need to do is fool the comp into thinkin its still in D or u will have a rev limiter. (like the one u have now with the car in park or neutral.) which is also the hardest part about doin the swap for a 6 speed type-s swap into the 3.0. (which i plan on doin sometime this year woo hoo)
Tristate ViP Crew
Originally Posted by SilverCL97
how much would a JDM H22A cost???
Tristate ViP Crew
Originally Posted by fuslove
And he hasn't let us know the time invloved or cost yet.
100% Dominicano
100% Dominicano
So of all that was said by everyone which engine w/tranny is best and fastest to put into an auto 1997 CL 2.2?
CL 4 LYFE
1 Post
Originally Posted by Zerostatic
It all depends on your budget and your ultimate goal. Personally, when you look at the cool hard numbers, for a 4,000-6,000 budget the fastest option would be to swap a 5 speed manual tranny onto your F-series and turbo it. Without being over-optimistic an F-series running mild boost can put down 220 to the wheels. A H22A swap which would end up costing similar money would put down a good 40 Horsepower less to the wheels. Of course a boosted H22A will put down more then a boosted F22 but like I said before your budget and your ultimate horsepower goal is what determines which route you take.
Woo!... you guys are really into swaps and you give alot of knowledge but I just need to know if I can get 200 to 240 more horse power when I swap and to what engine whether it be a F22/23 or H22 (becuase I don't know engines, I'm relying on your info).
I have this stupid 4cylinder automatic that goes no where very fast. If I have to swap my engine at a cost of no more than $3000 then I will; all I want is more speed (not track speed).
Tristate ViP Crew
http://www.topendmotorsports.com/eng...h22/index.html
Tristate ViP Crew
100% Dominicano
The H22 has more torque than an F series motor. You could boost the F22/23 but I'd rather have an H22-S/Euro R motor. I think an H22-S/Euro R would put up a nice run against a boosted F22/23.
CL 4 LYFE
1 Post
An H22 WILL NOT have more torque then a boosted F22/23. A boosted F22/23 would walk all over a stock H22, even it it the accord H22 type R. Think about it? How could a car that puts 180 to the wheels put up a nice run against a car that puts 220 to the wheels. (the turbo will add some extra weight, but not enough to make a difference) It will not. A 40 horsepower difference to the wheels is huge. That difference is like the difference between a GSR and a Civic EX.
Tristate ViP Crew
I'm not talking about a built turbo F22/23. There are many factors that determine an engines output. I'm not going to bother stressing my point because I could care less about F22/23 motors. If you have the money, do what's right for your car.
CL 4 LYFE
1 Post
Originally Posted by CL Platano
I feel ya bro, but some people live and die by the SOHC. I had that same problem with people trying to tell me that when I had my civic that a turbo charged D-Series will take a B16 with some work to it.
100% Dominicano
There is nothing wrong with SOHC motors. What is wrong is that some people believe that horsepower is everything.
Bisimoto Engineering is heavily involved in the Sport Compact race scene as well. The Team 400m CRX serves as a test bed for a majority of our products. The car 4882 currently has multiple world records in the pro stock/all motor class using a naturally aspirated SOHC Honda engine. Accolades this past season includes a 2003 IDRC All Motor Class Championship.
Dude, I'm not being biased here cuz I don't even have an F-series in my car, I have a J30 in my whip, I'm just not going to buy into popular opinion, I question everything and depending on your budget going the boosted F22 route can be better then doing a H22A swap.
Like I said before your budget and your goal dictate everything.
Trailblazer = SUCK
its more than likely the used the f22 because of the engine bay limitations and the oversteer probelms that happen when the H is put in. Its a lot easier to fit a turbo on the f22 in that small of a space. Not to say that the f22 isnt a good engine, but if one were to spend the money on a turbo, it wouldnt be much more to go ahead and swap an H in because of its increased performance and vast selection of parts. Far more than the f22.
dirtyspitshine
01-03-2023 08:23 PM
LECKEY73
02-22-2016 01:32 PM
justin7779
12-25-2015 10:33 PM
