driver sided LED light...
Does anyone know if there's a fuse for the red LED light on the drivers side that blinks when the alarm is activated, the reason i ask is cause mine doesn't seem to blink anymore and this happened about 2 days ago, how do i know if my alarm will still work if i don't know if the LED light is burnt out, a blown fuse for it, or if say the "theft deterrent" isn't functioning properly which may be preventing the light from blinking line normal?
say: zouts
Bagel Bomber
The chances of the LED being blown are slim - if you feel that is the problem, here are steps to go about replacing it. There is no fuse for the LED alone.
http://www.acura-cl.com/forums/showthread.php?t=181599
otherwise the LED has nothing to do with the alarm functioning correctly. A way to test your alarm would be to roll down the window and use the remote to activate the alarm. Reach inside of opened window with arm and open door (unlock door manually - not using power locks ect..
rockyboy
12-06-2022 02:29 PM
sockr1
10-01-2015 01:31 AM
