Does yours RUB...with a 1.5" or more drop???
You know him right?
I just wanted to know if a 1.75" front / 1.5" rear drop will cause rubbing? I was thinking of getting Neuspeed Sports. The only problem is that I may actually have 2 people in my back seat sometimes (300-400lbs extra).
Does anyone have a problem with rubbing (with or without passengers)???
A local shop said the Neuspeeds would rub whereas "the Eibach Sportlines would not because of some ingenious engineering". That seems wierd to me.
Moderator Alumnus
no offense, but that shop sounds full of shit to me.....
i have neuspeeds and i have never rubbed even with three big guys in the back seat.
a good tire+rim combination will keep the height of the tire the same as the stock 16's with the tires. so if you dont rub with them, you probably wont rub with the 17's.
ingenious engineering my ass...... neuspeeds have a stiffer spring rate than the eibachs anyway. your local shop sounds like a buncha idiots IMO.
in short.. no, they wont rub
You Fawkin Kiddin Me!
I have eibacj sports 2+" drop, tokiko shocks and ST sways... I run a 17" rim with 225/45 tires...
Normally all i rub is my undercarriage over large speed bumps, and my noise and exhaust on inclines w/ or w/out passengers... The only rubbing I have with passengers is when i hit large bumps while driving, then the tire rubs the wheel well...
2 inch drop on 17's with 205/40 tires. Never rubbed the tires even with 5 people in the car.
Only problem is going over speed bumbs which will rub the frame the exhaust piping, or sometimes even the headers.
I HATE SPEED BUMPS!!! :angry:
You know him right?
The Creator
all depends on how wide and what your offset is.
as for the eibach vs. neuspeed thing... my only guess would be that maybe the eibachs are progressive while the neuspeeds are a fixed rate spring.
that would allow the eibachs to stiffen up a lot more during body roll.
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
damn, someones learning
Moderator Alumnus
they are both progressive springs. if anyhting the eibachs go a little lower than the neuspeeds.
im with soop... if you have a bad offset, youre gonna rub with pro-kits.
You know him right?
I hope this doesn't sound stupid (I don't know much about offset and that kind of stuff). Is there anyway to figure what my offset is? Is it from the manufacturer of the rim?
steady gruuvin'
i got the sportline kit.....it does not rub at all. it did when i had 16's and some big ass tires like 55's or 60's or somethin....But that was only when I had 2 people in the back...But now i got 17's with some 40's and there isn't any rubbing...i think that shop is full of shit also....ask them which set is cheaper, and if they say neuspeed then go somewhere else, cause they're tryina dick you around. deal with people that actually want to help you, and not just take your money.
emailnatec
29
09-28-2018 04:27 PM
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
us285126
10-02-2015 02:03 PM
4drviper
09-23-2015 07:42 PM
