Does this clutch kit/flywheel look good?
B A N N E D
http://cgi.ebay.com/ebaymotors/90-HO...68887639QQrdZ1
There is also a exedy clutch, pressure plate, and fidanza flywheel deal on their for 369 shipped. Should I spend the cash on it? I'm looking for something that will grab a little better, but Don't really need the best. Thanks.
from what I have found I would just go with the exedy stage 1 on ebay for 240 shipped and then if you want buy around a 12pound flywheel seeing how the flywheel that comes with the exedy kit you found would probably be to light for our cars
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
get the exedy 1
B A N N E D
Right, but I am having trouble finding anything close to the quality of the exedy/fidanza one I found. The link I put had an exedy clutch, but is pretty vague on the brands of the other things...I want to get the flywheel at the same time because a buddy of mine is putting it in for me, and rather than get in there and find out that it needs resurfacing, or replacing I will just get it now. The only problem is the fidanza is 8 lbs, where I want to stay 10+ lbs, but it is a really good deal....I am torn.
Has anybody heard anything about XTD clutches I found this deal
http://cgi.ebay.com/ebaymotors/90-02...spagenameZWDVW
B A N N E D
I have heard some pretty bad things about them, like going out in just a few months... Still doing research on clutches, and flywheels.
Nom Nom Nom Nom
The first time I did it, i feathered it into first to eliminate wheel spin ran up to about 6k rpms, and to my surprise everything in my pocket under the cd player, fell out. Thank you wheel hop.... Still cant find the lighter that was in there.
1997 2.2CL black on black
B A N N E D
I just got this one here.http://cgi.ebay.com/ebaymotors/EXEDY...QQcmdZViewItem
4x4- fat chicks cant jump
One custom CL
dont get it
they are horrible. no grip at all. not stage 3 or even stage 30 for that fact. they simply suck
My kit says it only comes with the Release bearing. Should I get any other bearings/seals to replace while I'm in there?
I'm going to replace my clutch with the exedy stage 1 eventually. It's the best bang for the buck. Can't go wrong.
B A N N E D
Originally Posted by keithseymour
Definately get a honda throw out bearing.
One custom CL
I went with the chromoly flywheel for the simple reason that it can be shaved just like the OEM flywheel. I believe the Fidanza comes with aluminum inserts
mugen_kid
11-13-2015 10:38 PM
