Does anyone here have ground control coilovers?
Old 12-19-2003 | 08:57 AM
nujunglist's Avatar
El Donko of Punchstania
Any of you guys that have ground controls, would you mind sharing your thoughts on them? I have a set at home that I havent installed yet, but I am torn between getting some new shocks and installing the ground controls, or just selling the ground controls, and putting the money towards a set of teins.
Old 12-19-2003 | 10:29 AM
CLpower's Avatar
teh Senior Instigator
I had them when they first came out and wasn't happy, i've heard they have improved. If you are going to do any sleeve coilover setup they are the one to do.
Old 12-19-2003 | 11:02 AM
phil2's Avatar
has Gloryhole Girls in
had them on my rsx-s and they were the worst quality coilovers out there
car rode like shit dont waste your $$$ :o
Old 12-20-2003 | 01:25 AM
CLstunner's Avatar
actually, i heard they were the best sleeve coilovers. just buy a quality set of struts and they should be good
Old 12-20-2003 | 07:04 PM
CLpower's Avatar
they are by far the best sleeve coilovers out there, but that's not saying much. However GC's are very popular on the SCCA circuit, so they are having success
Old 12-20-2003 | 07:48 PM
ib_jimmy's Avatar
but its still sleeve coliovers....and all sleeve coilover suck...JMO
Old 12-20-2003 | 07:56 PM
Katies99CL's Avatar
i want a bimmer =(
well...the coilovers were how much? 250? good strut/shocks will be another 400 easy, right there thats 650...you can get the TEIN basic w/ non-adjustable shocks for about that...or if you want adjustable shocks it's a little more.
I lowered my car w/ coilovers on stock struts and it was the WORST decision i ever made, i would advise you NOT to do the same. Since it would make no sense to buy aftermarket shocks now, I am just saving up for the TEIN set-up. Good luck w/ whatever you choose.
Old 12-20-2003 | 09:19 PM
baka_t's Avatar
The movement has started
Well all depends how much you want to spend...Im riding on skunk 2's currently with kyb agx's the ride is ok unless you hit a series of bumps. The ride of the G'C's are nice with either a koni yellow or kyb agx. (a couple of my friends have that setup)Personally i think the ride with springs is the best. If your stuck on coilovers I would get a set of teins they ride good. But still if you hit a series of bumps or potholes it gets bumpy. In whatever case get your car aligned when you get ur suspension on. Believe it or not it affects the ride quality i just got mine aligned and the ride improved by 70% then when it wasn't aligned.
Old 12-21-2003 | 01:48 AM
CLstunner's Avatar
does it really improve the ride quality? i should get my car realigned again
Old 12-21-2003 | 02:39 AM
r3mix3r's Avatar
"i just got mine aligned and the ride improved by 70% then when it wasn't aligned."
Arent u exagerating a little? How much negative camber did you have? I dont see how it could make such a difference.
Old 12-21-2003 | 01:47 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
if you go a coilover go a full dampner system, like a tein or a apexi or a nex setup, i love the teins but im leaning over to the apexi setup
but try the teins they ride the best and give you the most out of your money and also if you have the money but the edfc for them too so you can be a totally custom ride setup
Old 12-21-2003 | 03:42 PM
baka_t's Avatar
Well i wouldn't think it wouldn't really matter but the car drive more smooth tracks better and bounces less i couldnt believe it.
Old 12-21-2003 | 03:45 PM
baka_t's Avatar
well it did improve enough to notice it. The ride got way better. But then again i had about 3*+ negative camber and my toe was way off.
27trains
4G TL Problems & Fixes
09-30-2015 10:44 AM
MrHeeltoe
09-29-2015 11:43 PM
adreano17
09-29-2015 09:48 AM
MrHeeltoe
09-28-2015 06:43 PM
4drviper
09-23-2015 08:42 PM
