Do I need to shave off anything...
...if I'm going to put in an aftermarket front strut bar for a 97 2.2??? I know the 97 2.2 strut bar topic has been discussed before but I don't remember getting any clear answer whether or not you need to shave off anything to make the strut bar fit. Again, is this a perfect fit or is there something that I need to shave off???
Thanks, guys.
Thanks, guys.
The front bar is a perfect fit and you will not have to remove the stock bar or anything else for that matter. The rear upper fits after slight modification and the rear lower fits perfect.
Scooby Guru
Why on earth would you want to replace the stock brace (which ties the two strut towers and the firewall) with a less rigid aftermarket one (which doesn't connect to the firewall)? And I didn't have to modify anything to get the rear brace to fit (except for cutting the trunk carpeting a bit.
The Stock bar SUCKS.....I felt a big difference with an after market one. Here is a pic hope it helps. And ohh yeah i did take off the stock bar. Hope this helps.
Scooby Guru
I fail to see how the one piece stock bar that bolts to the strut towers and the firewall is noticeably worse than a flimsy 3 piece aftermarket bar that is essentially held together by pins (bolts, which allow twisting) and doesn't attach to the firewall. But hey, if you like it!
