Do I need a new battery or what (Blinker)
Old 10-30-2004 | 03:10 PM
Mach30SiR's Avatar
Bagel Bomber
I just got my cl a few weeks ago. I've noticed lately that when i put on the blinker or load the system up, the lights dim, and brighten and dim and brighten, in unison with my turn signals.
I had acura test the alternator out put, and they said it was fine. Its a delphi alternator, not delco, so it was probably replaced once already.
So whats up? Battery, Relay somewhere, what would you all suggest checking now? maybe batter output??
The battery in there is an Acura/Honda motors battery, could be origional.
1998 3.0
Old 10-31-2004 | 09:41 AM
Mach30SiR's Avatar
Bagel Bomber
I'm starting to think i should have labeled this "look at my new rice hood" i would have gotten a reply by now.
Old 10-31-2004 | 11:41 AM
circuitcah's Avatar
I have the exact same problem w/ my '98 3.0. Others on this board have posted about it too. I have replaced my alternator and checked all of the grounds that I can see, but still have not fixed the 'problem'. I have yet to find a posting on this board about a sure fix to this issue. Most say it's the alternator, but with a new one in place I saw no change.
Hope this info helps some and if you find a solution, let me know!
Old 10-31-2004 | 12:13 PM
wilp99's Avatar
try cleaning the battery posts. even if they look ok. and make sure ur chassy groud is not corroded where it connects to the car.
this is prolly the most anti-rice website in nerdville.
Old 10-31-2004 | 01:01 PM
uiskibum's Avatar
its paid for
it does sound like a bad ground issue. all i can think of to check wilp already mentioned
Old 10-31-2004 | 01:12 PM
Mach30SiR's Avatar
Bagel Bomber
:: going ground sanding ::
i'll let ya guys know. Correct me if i'm wrong, but the car runs off the battery not the alternator right? The alternator just keeps the battery charged at all times?
Old 10-31-2004 | 01:23 PM
uiskibum's Avatar
its paid for
to my knowledge when the car is running it is getting 12volt from the alternator. The battery is used to start the car, run acc. (when the car is off), maintain certain settings (radio, clock, etc.)
Old 10-31-2004 | 02:11 PM
Mach30SiR's Avatar
Bagel Bomber
welp cleaning all the grounds didn't work, there wasn't much to clean anyways.
any more ideas? its pretty annoying.
Old 10-31-2004 | 02:23 PM
ajbent86's Avatar
maybe your voltage regulator is goin bad.......
Old 10-31-2004 | 03:41 PM
wilp99's Avatar
check ur fuseable links, sometimes they get coroded and thin and that would cause poor power xfer
Old 10-31-2004 | 05:04 PM
Jamz's Avatar
CAFFEINE SLAVE
mine has done the same thing since I got it 2 1/2 yrs ago
I haven't thought about it much since it only happens sitting at a stop with the blinkers on
Old 10-31-2004 | 06:49 PM
Mach30SiR's Avatar
Bagel Bomber
please elaborate, whats a fuseable link?
Old 10-31-2004 | 07:58 PM
circuitcah's Avatar
The voltage regulator is built in to the alternator. Changing the alternator changes the regulator....
Old 10-31-2004 | 10:01 PM
wilp99's Avatar
a fuseable link is like an inline fuse. but it melts when a surge is enough. instead of the fuse "pop".
Old 11-01-2004 | 12:28 AM
legendaryCL98's Avatar
'07 November = STI
same here
i dunno what the problem is.. but the car runs okay
Old 11-01-2004 | 02:42 AM
CL-zero's Avatar
what i notice is that intake and exhoust sound change as it dims.
i think it is kind bad for car so i'm tring to find way to fix it but i have not.
Old 11-01-2004 | 08:12 AM
dogfight's Avatar
all "modern" cars run of the alternator... the battery is for starting and powering accesories when engine is off. you ca prove this by disconnecting the battery negative terminal while the engine is running... it will continue to run.
Old 11-01-2004 | 12:47 PM
mfkitson's Avatar
50? you must be kidding!
agreed that the car runs on the alternator, BUT, the battery can cause issues, if it's bad or going bad it can cause a "drain" on the alternator, so to speak, if it's getting to 4 or 5 years old, you may want to repalce it and see what happens....but it could be grounding problems too...
Old 11-02-2004 | 07:46 AM
CL-Sweetness's Avatar
9th Gear
Just my ...
I used to have a 98 3.0 and it did the lights dimming thing. I even noticed the headlights dimming with each click of the turn signal. I just got used to it after a while. But... I totaled the 98 (not my fault) and I now have a 99 3.0 and I have no problems with the lights dimming. I dunno...
Old 11-02-2004 | 04:09 PM
proaudio22's Avatar
-S namyaC-
The alternator in our cars is weak below 1500rpm. Put the car in neutral and step on the gas - you'll notice the "blinking/dimming" goes away.
Old 11-02-2004 | 10:09 PM
Mach30SiR's Avatar
Bagel Bomber
so i turn the car off, and checked to see if the battery was the cause, and the lights dont dim or anything when the alternator isn't running, anyother ideas.
My acura dealer said it was putting out 14 volts at idle and a load. It really seems to only be the blinkers that cause the load, its not even the hazards that do it. the hazards dont cause a fluctuation.
Old 11-03-2004 | 03:21 AM
CL-zero's Avatar
Also when i put AC or defroster on rear window on, the dim goes away.
i can't understand this
Old 11-03-2004 | 05:19 AM
wilp99's Avatar
thats cause anytime theres a load of 12v or more from accessories, the alternator automatically starts to recharge the battery...
if u disconnect the positive on the battery while the car is running the car will run just as good as if it were connected. thats because the car runs strictly on the alternator. the battery is used for starting and kind of a "cap".
Old 11-03-2004 | 08:44 AM
Mach30SiR's Avatar
Bagel Bomber
yep, we defintaely have the same problem. I tried putting the car in neutral and going to 2k rpm and the dimming went away, i'm thinking voltage regulator or something.
Old 11-04-2004 | 10:03 PM
Mach30SiR's Avatar
Bagel Bomber
i shall not let this die.....how do we fix this, i'm not the only one searching for the problem.
Old 11-05-2004 | 12:06 AM
circuitcah's Avatar
My guess is that there is a common point somewhere in the grounds or 12V feed wires in the car that get to a point where they have a high resistance. I know Acura that these cars did not do this when they were new, so it is something that develops over time. The trick is to search the electrical system and find the bad connections..... where to start.....
Old 04-29-2006 | 03:28 PM
Mach30SiR's Avatar
Bagel Bomber
alright back to the drawing board - alternator was replace today with a delphi (oem) from the dealer, still happens even more noticable now. is only low rpm's
Old 04-29-2006 | 04:19 PM
spencer_homer's Avatar
i like acura
when my subs hit, my lights dim
Old 04-29-2006 | 04:59 PM
Mach30SiR's Avatar
Bagel Bomber
get a cap for your car audio system. this is a different problem.
Old 04-29-2006 | 05:26 PM
i like acura
i know
Old 04-30-2006 | 12:11 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
get a cap, and you'll be aight. My 3.0 farrad runs smooth, no major drain off the battery, 3.0 farrad and optima for the win
Old 05-03-2006 | 12:45 PM
Mach30SiR's Avatar
Bagel Bomber
Next check will be grounds. But considering the problem goes way when the engine is at higher RPM's (Alternator is spinning faster) this might be a sign of a older battery. Never had it die on me before, and the car starts up on the first time every time, so i donno?
Old 05-03-2006 | 01:03 PM
ib_jimmy's Avatar
get a strong alternator...if u have a system...get a cap.
Old 05-03-2006 | 02:24 PM
Mach30SiR's Avatar
Bagel Bomber
This was happening even before the system was put in, and even happens when the system is turned off. So i really think its independent of any system draw. ??
Old 05-03-2006 | 02:29 PM
ib_jimmy's Avatar
have u check ur timing? if the time is off slightly it would do that too.
Old 05-03-2006 | 03:57 PM
Mach30SiR's Avatar
Bagel Bomber
wish they made .05 farad caps for my blinkers, oh well, i've been dealing with this for a year now, so i'll wait until the battery takes a dump and see if a replacement is whats needed.
What kind of battery came with acura's stock?
Old 05-03-2006 | 04:12 PM
ajtcl's Avatar
Peace, Love & Acura
I had a similar problem, but then my alt took a crap and I replaced it with a stronger unit and now it doesn't do it. Replace the atock 80 ampre alternator with 120 ampre alternator and you'll be peachy.
Good luck
Old 05-03-2006 | 04:19 PM
(Mid-Atlantic)
Or your alternator is failing
Old 05-03-2006 | 05:15 PM
Mach30SiR's Avatar
Bagel Bomber
Just was replaced with a delphi (OEM) at the acura dealer.
Old 05-03-2006 | 05:22 PM
Gaujo's Avatar
HAHA so true.
Fixing problems = boring
nicey ricey = lots of attention
