Disabling the secondary o2 sensor
Old Jan 28, 2006 | 12:06 AM
acuratl_2nr's Avatar
Hey,
My cel light is on and it's throwing me the secondary o2 sensor malfunction code. A friend of mine told me that the 2nd o2 sensor doesnt really do anything so I looked on the net ways to disable it and I didnt find good information,... It's pissin me off cuz my car is in "limp mode" with the cel on and performance/gas mileage sucks,.. Does anyone know how to trick the ecu into thinking that the 2nd o2 sensor is working??
thanks,
M
Old Jan 28, 2006 | 12:40 AM
xrunner86x's Avatar
A-CL Totaled Member
go to mods, o2 sensor override http://home.insightbb.com/~niedejb/
Old Jan 28, 2006 | 09:56 AM
wilp99's Avatar
the secondary o2 sensor wouldnt cause your car to go into limp mode. its only purpose is to tell you when the cat is doin its job or when its not. most obd1 cars done even have one cause they assumed then that a cat cant go bad.. but that diagram works ^^^^^^^^
but instead of just tyin it up out of the way make sure you reinstall the sensor.
Old Jan 28, 2006 | 09:57 AM
wilp99's Avatar
and that mod i dont think will work for you since the sensor is bad. it tricks the signals its gettin from the sensor to the ecu so the car thinks your cat is working.. so i do beleave your fresh out of luck as far as trickin the car. just replace the sensor.
Old Jan 28, 2006 | 10:04 AM
I'll probably give it a try anyways since I don't have much to lose and if it works it'll be better than forking out 200$ for a sensor...
Old Jan 28, 2006 | 10:08 AM
I'm also pretty sure that my car is in limp mode because I have noticed a difference in performance and gas mileage.
Old Jan 29, 2006 | 10:10 AM
wilp99's Avatar
you can get a universal fit o2 sensor for 70$ at autozone.
RobbDizzle
Oct 15, 2015 11:16 AM
joflewbyu2
Oct 8, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
