couple things to help your car run better
heres a couple things u guys can do to help your car run a little better.
honda/acura recommends a valve adjust every3-4 oil changes
change your oil every 2500-3000 miles
change your transmission fluid atleast once year
if you have vtec i recommend using chevron with techron and pumpin 89 or 91 octane. it has been proven that techron has additives that will clean the corrosion on your valves.
also a good fuel system flush (seamfoam) is recmonded atleast once a year
a coolant flush is recomended every 2 years.
do these couple things and your car will run fine
One custom CL
i just bought 3 cans of sea foam
based on the instruction they seem to work miracles
i used some to clean out my plugs and shiiiiiit
it works fucking great
Who the F*** is Chucky?
sea foam sounds pretty good...
i was reading the instructions of where to add it tho...2 questions:
1. The oilcrank is just where you put oil into the engine correct?
2. Does anyone know exactly whree to put it into the carburator because they listed the vacuum line and one or two other areas...i have no idea
gas tank is easy enough haha
Fast Foward>Rewind>Play
i just my tranny rebuilt. this coming up weekend, this is my to do list:
Oil Change
Transmission Cooler
Sea Foam
Fuel Filter Replacement
Custom Cold Air Intake.
Oil Change
Transmission Cooler
Sea Foam
Originally Posted by Palayah8ta
is there a valve ajustment DIY?
https://acurazine.com/forums/showthr...lve+adjustment
(search function is a wonderful thing...
