Clogged Washer Lines?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
You can clean the holes the water come out of with a sewing needle or pin, just poke the holes, if that doesn't work, I would pull the hoses off of the nozzles with the hood open, and see if you can get fluid to come out of the lines, if it doesn't come out with the nozzles not on, then it's the nozzles, you can also replace them for about $10 a piece from the dealer, I have a set on each of my hoods. Most likely it's the nozzles that are plugged, try the pin/needle first. Also make sure your fluid is full
MrHeeltoe
20
02-23-2023 01:54 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
