cleaning air intake
cleaning air intake
i bought the K&N cleaner and it says to wash the intake with water before adding the cleaner......idn sounds kinda weird. Should i just follow the instructions?? by the way i have a aem short ram and its getting alot of debris in the slits.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by shnee420
follow directions
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by zhouz
last i read the instructions i remember you had to apply cleaner, let it soak in and THEN rinse with water. then after its dry you oil...
Uses turn signals in my
Originally Posted by Trijicon
make sure not to over oil the filter and let it soak in on a newspaper for 12 hours or so. You do NOT want any oil getting sucked in and onto the MAF.
Originally Posted by TCM 01 CL-S
Do the 1st gen CL have MAF's? The 2nd gen uses a MAP, just wondering if the 1st gen is different.
actually.... um, I'm not sure to tell ya the truth... I just picked up a CL today for my son and I was talkn of my experience with my "G"....
However the advise to not "over oil" and let it sit awhile still stands
(Mid-Atlantic)
(Mid-Atlantic)
1st gens have a MAP too
I need to clean mine out, its been like over 6 months, (I feel bad for ignoring it for so long). I don't really have 12 hours to let it dry because I have to do the work at a friends because my apt complex doesn't allow you to work on your car. Can you just compressed air the thing ?
My apt complex has the same policy (but I work on it in the parking lot anyway, just out of the way), but I'm sure removing the intake won't be an issue.
I mean, you'd be out there for like 2 minutes, and then 2 minutes putting it back on later.
I wouldn't use compressed air.. I'd be afraid of blowing right through the filter, or pushing a small rock or something right through.
Just come home, remove it, wash and oil it, let it dry over night, and put it back on in the morning.
(Mid-Atlantic)
(Mid-Atlantic)
Alright I might do that, Its a little more involved but if I do it right it will take about 5 mins to get off, and another five to get on. Its a cold air intake so I have to remove the fender wall. Thanks for the help
i have a cai as well.
i just pull the flap off from underneath the front bumper light. after you've loosened the filter from the piping, you can just slide it right out from there.
i found that it's a lot easier and faster than removing the fender wall
mrkingstonvi
02-22-2016 01:53 PM
