checking the srs light?
ENGAGE MY VTEC BABY!!!!!!
i went out to the car today to check my srs light. you check it just like the check engine light right? well i tried jumpering the female piece and nothing happened. is the srs light different from the check engine light? there are a green and red wire right? and then they are in a holder behind the glove box right? i stuck a paper clip in the red and nothing happened, and the green the same way. is there any specific way to stick the paper clip in? does the car need to be in accerasary mode? should i do it when its off and no keys in the ignition? let me know everything i need to know. and if anybody see PRadnoski or know how to contact him let me know cause i need my parts and i think he scammed me.
thanks fellas
later
thanks fellas
later
Swaps? $3000 for 50HP? :(
![](http://home.insightbb.com/~niedejb/pics/jumper.jpg)
Use a paper clip in this connector to "jump" one side to the other.
Turn the key all the way on w/o starting it.
The SRS light should flash a code. The codes are on my website or PM with specific questions.
hey the abs light blinked a 3 quick and then a 2 quick, but i think its a 32, a pulsar lt front. how much will this run me to fix? let me know if i messed up.
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
drewdeezy03
09-03-2015 08:04 PM
