Check Engine CODES!!!!!
"FROGGYSTYLE"
coming home from a drive the other day and my check engine light came on. well it has done this before and it was an insufficient flow in the egr valve. so i thought nothing of it. 5 min later the check engine light starts to flash at me. i gave it some more gas and it stayed on steady. made it to autozone and pulled codes on it and it came up p1300, p0302, and p0304. the last 2 said cylinder 2 & 4 miss fire. the p1300 said something weir and i didnt understand it. all i know is it deals with the ignition system. could any body help me out on this one. thanks
sorry can't help u on your problem but i just bought an 03 cl and my engine light is on i brought it to dealership. they told me it was an egr valve? what is that valve? what did u do when yours had problems?
"FROGGYSTYLE"
the egr vavle is located right behind the vtec selonoid. i took it off and cleaned the carbon build up and then i took a small pipe cleaner and the top part of it.. i am not sure on the new ones. should still have some type of warrenty on it
"FROGGYSTYLE"
Stupid Whooras
![Smile](https://acurazine.com/forums/images/icons/icon7.gif)
I know these threads are old, but in case someone at least reads over this in the future:
If cleaning the injectors does not help, clean the ports to your EGR valve. Also, there is an access plate on the intake manifold. I was getting the codes P0303, P0304 and P1300. After removing the access panel on the intake manifold, I discovered 3 out of 4 intake ports to engine were clogged with carbon. Using carb cleaner, screw drivers and chisels, the carbon build-up was removed. The car runs GREAT now. After physically removing carbon build-up, I would suggest running Chevron Techron through the system to finish cleaning up.
Hope this helps anyone who reads this since none of the other posts helped me.
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
