Catalytic Converter / Cigarette Lighter Help!
Hey, anyone know where I can buy a new catalytic converter for my 97 3.0 CL? My check engine light came on, and was a result of the catalytic. The dealer wants $700 for it, which is a little crazy.
Also does anyone have the cigarette lighter? I need the actual unit that heats up the plug that you see on the outside.
PM Me if you have any info. Thanks a lot
I'm a llama :(
How many miles are on your car? Our cats are made to last a long, long time, so if yours went out, you've got a problem. If you get a new cat without fixing this problem, it will go out again. It can be as easy as a fouled spark plug. If you get an aftermarket cat it won't be as good as OEM and will only last a few years. That's okay if you don't plan on keeping the car for very long, but if you do, then get an OEM one. Don't know where you can get a cheap one though.
