Can someone educate me on camber kits really fast?
Where would I go about to get a front and rear camber kit? Once installed, I still have to take it to a shop to get it aligned? I am dropped on D2's if it matters, thanks.
yup thats right... depending on your camber you might only need eather front or back.... i only needed back and i was droped on sportlines.... gotta egt the camber adjusted as well as the alignment
The Hefty 2.2
just do the washer trick in the rear... its about $5... as for the front... ball joints might be the best, unless u point ur fender and get the anchor bolt kit. and yes... ur gonna needa get it aligned again because when putting in he camber kit, parts that relate to camber issues are being unscrewed and played with in order to install the camber kit.
I'm a llama :(
Im No Superman
Scissor Me Timbers!!
I believe neuspeed sells a camber kit for the 1st gen CL www.neuspeed.com
Nom Nom Nom Nom
my camber in the rear is whacked....If you are looking at the back of my car, the right tire looks like the camber is fine, but then the right tire is -.... It basically looks like this / | Why could that be?
I'm a llama :(
Nom Nom Nom Nom
Originally Posted by Motohip
I know....It sucks....
I saw that today and was all
No wonder why my car rides like crap all over the freeway...Cuz if i were to guess, the front is probably the same way.... I think you might be able to see it here
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-28-2015 05:43 PM
