bumpstops?
bumpstops?
I recently lowered my 97 3.0 CL with suspension teq sport springs and it dropped it about an inch and a half. The problem is my rears are making mad nose. I swapped out the struts with just some cheeseball monroes, and have taken it to the shop twice with the final diagnoses being I need a camber kit. They say the control arms are whats making the "bump" noise. I've already cut the bumpstops, and the struts look like they have a good 3-4 inches of movement. Does anyone have any suggestions for me?
thanx guys
thanx guys
No Show All Go
when I lowered, I was doing 80 and hit potholes (more like mooseholes) but I smelt burning plastic and rubber. i I figured to take out wheel well plastic, lol my car doesnt smell any more. Did a shop lower it or did you
Im No Superman
ive got the same exact springs.. i havent had any problems with them.. however if your lower part of the spring is not seated in the correct part of the perch you will get a bump from the springs compressing against each other.. also check to make sure you have a bushing on BOTH sides of the firewall on top. you did reuse the plastic liners for the perch and top of the strut right? i just took out my bump stop all togather after i installed my kyb's. i love these springs by the way. i get a stock like ride with bein alittle lower.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
stRodda
04-07-2006 01:31 AM
