bumper !!
muahahahaha
bumper !!
i tried blackhousing my lights but just cant seem to get the dam bumper off...theres like 2 clips underneath the damn headlight and a screw to the side of it its a pain in the mothereffin ass please someone help the blind here...show me the way
quoted from 97acura3.0cl
"get a 12mm socket and 2 extension wands, and a srewdriver, stubby and long screwdriver
there are 1 screw on each side that hold the lender liner to the bumper towards the bottom some have it towards the top, then there should be a hole on the inside of the lower grill next to the inside part of the turn signal, take a screw driver and unscrew this screw
pop out the turn signals, look inside and up to your top left inside if you are on the driver side there is a bolt, use the 2 wands and the 12mm socket and undo this bolt, then go to the inside of the grill on the other side of that screw there is another 12mm bolt, it will be on the other side of the plate next to the first bolt, take off the other one, repeat to the other side
when this is down it will be loose, lift up and pull away, this is the easiest part, when you put it back on it will be a little tricky to align it but put it the same way you got it off"
quanaman
01-09-2023 07:33 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
