Broken Seal
Old 06-28-2008 | 01:53 PM
YtseJammer's Avatar
Low and Slow
Broken Seal
So a seal in my valve cover broke and now there is a bunch of oil in one of the spark plug holes. I was checking my spark plugs and when I pulled out the last wire a bunch of oil flew out with it.
I know I need to go out and buy a new seal, but what is the best way to get the oil out?
I'm debating on whether or not I should just take it to a shop and have them replace the seal and clean out the oil.
Old 06-28-2008 | 02:01 PM
DaInFaMMuS1's Avatar
My dad's 93 accord had the same problem. I'd get that fixed asap, cuz one of his went then the rest progressively got worse. Me and my dad used a thin stick with paper towel wrapped around it to clean out the spark plug areas till he could get it to a shop. maybe that will work for you too.
Old 06-28-2008 | 04:51 PM
TexasHonda's Avatar
Usually valve cover gasket and all four spark plug seals are replaced at same time. Felpro makes a nice kit that runs about $20-30 (haven't priced recently).
Oil in spark plug well is removed by putting a small suction line down inside the tube and suctioning w/ shop vac or engine vacuum source to pull the oil out. Then mop w/ a paper towel pushed w/ screwdriver to remove remaining oil before pulling plug. Use anti-sieze (sparingly) on the plug threads to ease future removals.
Some 2.2L engines have additional orings under the rocker arms assy. I think all VTEC engines do not. These extra orings are included in Felpro kit if you need them.
good luck
Old 06-28-2008 | 10:03 PM
YtseJammer's Avatar
Low and Slow
Awesome. Thanks for the replies guys!
Old 06-28-2008 | 10:45 PM
YtseJammer's Avatar
Low and Slow
Just ordered the Felpro kit online for $25, should be here in a few days. Thanks again.
Mike734
12-10-2021 01:25 PM
dainmezron
10-16-2015 06:56 PM
steve
09-30-2015 09:23 PM
polish_pat
09-30-2015 12:22 PM
juanrl
09-29-2015 03:25 AM
Quick Reply: Broken Seal
