blackhousing failure..
yesterday i was all pumped up cuz i was gonna do my black housings
..i knew it was gonna be a bitch to take the front bumper off since i never did it before. i spent about 2 hours trying to take that thing off but it just didn't want to lift off
i followed the DIY instructions but the little bastard just didn't want to come off, so i just bolted the bumper back on and left it.. ..i was thinking that it was a sign not to do it cuz it would look bad but i dont care i just want them done
so now i got spray cans sitting in my car waiting to go on but i can't do it cuz that damn bumper what do you guys think?
..oh and im ready for all the & smilies, so bring them on...
you can't take off the bumper? the only thing you need to really take off are the 4 bolts in the center area, one on each side. then take off the lame tiny fender ones and you're good to go
but... blackhousing on a primrose? IMO doens't go well, unless you have a CF hood or something, just my two cents
yadadaa
ahah. just messin man. i would probably have the same problem if i tried it. after you get all the bolts off, try pulling it a little to see if other bolts are still screwed in. dont pull to hard though.
Originally Posted by SwervinCL
After you take out the 4 bolts does the bumper at least feel loose wwhen you left up on it?
Nom Nom Nom Nom
When i did mine i had a problem with the right side. So i just went to the left side and started with one side at a time. You have to pull up and out and the same time. Just try one side at a time..>There are like 2 plugs on the bottom under the car. Make sure you take those out.
Nom Nom Nom Nom
I dunno. If its real loose, it should just pop off...(your not gonna break your bumper.)
Make sure its not catching on your headlights causing you not being able to lift it up all the way
Nom Nom Nom Nom
You see the black brackets on each side right under the headlight openings. Those have 1 stud a piece that stick out with a head on it...I just kept liftin mine up and down kind of fast till it came out..(temper took over)
Im No Superman
took me and my TL buddy 2 1/2 days to get my bumper off finally.. u take out your corner lenses there are 2 bolts on each side.. thats what we missed.. and yes those clips pop off i didnt even put em back :/
2600lb CL
CL smashin
It's not lift and pull folks. After you got all the bolts, screws, and the bumper lights off, you have to push down on the bumper, kind of hit it downward your hand, then pull the sides out (the wheel well part of the bumper on each side) and the bumper should come off. Putting it back on though is a BITCH!
Nex
09-09-2010 11:24 PM
