Big Rotor Kit
Originally Posted by CL Platano
That was a Brembo Gt Turismo with the lines , rotors and calipers..the $500 dollar kit is only the rotors and some kits throw in the calipers
I care more about braking power than looks. Looks are a bonus though.
I used to not worry about brakes, but with this heavy ass car I've had too many close calls. Brakes are the most neglected parts when mod'ing.
The link you sent said it was fronts only for $500
this heavy ass car is a pain to stop, I'm doin cross/slotted rotors, new pads, and ss brake lines, in order to stop this honkin piece of metal. Just wish my ABS light wouldn't keep coming on AGAIN
I'd take care of that ABS light. Would scare me to be driving like that. And check out this forum...
http://www.accordinglydone.com/forum...356#post147356
Find your way to the stop drop and roll section for brake info. They all say get blanks, so I got blanks.
Originally Posted by azian21485
sorry but nothing but nothing on the list will help except for the new pads..and they'll only help slightly...i guess you can say you have cool looking brakes though....
If you think about it another way, like it could prevent an accident that could cost thousands, then it's a bargain. I don't have that kinda money either, so I'm going a different route. Prelude rotors and NSX calipers. Only costing me about $150 not including pads.
PS. You and chucks have like the same exact avatar.
Yup, NSX pads. Then I can pretend to have one at the auto store.
Originally Posted by chuckz
its not just the pads helping to stop quicker, its a combination of things helping. rotors, pads, and i believe lines. if it was just pads helping to stop quicker infinity would have just put good pads on the g35, instead they installed the brembos on to help reduce the distance needed to stop.
as not to thread jack (and i do it alot), quick answer: once you lock up your tires you are not going to stop any faster
Originally Posted by wilp99
your right he'd better change it or im gonna break his hips.
so after that youd be buying nsx brake pads? they have 2 pistons right?
i believe the whole purpose and design for ABS is to stop the brakes from locking up like when u have brakes with no abs. the technology abs uses is when u hit the brakes there is a constant force applied to the rotors off and on. its kind of like a piston. when the engine is on it constantly goes up and down. the calipers do the same, they go in and out to slow the car faster and stop ur brakes from locking up.
i had mine first!
i had mine first!
I dont think even a pro can stop a car faster than ABS.
abs will never stop a car faster than threshold braking..it was designed to do other things
i had mine first!
i had mine first!
mine looks better
I have synthetic Dot 4 that is suppose to withstand higher temps than your usuall Dot 4's
Also, when it comes to pads, go with the "green stuff".
threshold braking will stop your car faster than abs....abs just helps prevent you from going way over the tire threshold so you can still have some sort of manuevability (like dodging a car or something)...but you are already over the limit once abs comes on (depending how good the system is)
He's right guys...once your over your tires limit, you actually take longer to brake.
and yeah, wilp's brakes look better than yours chuckz
