Battery or alternator shot? or something else?
so I was driving home just now and the "battery" light on teh dash came on and all the lights dimmed.
earlier today I started hearing a whining noise coming form under the hood. I popped the hood just now and it sounds liek the whining is coming form the drvers side around the transmission...
the whining makes me think it's the alternator that's shot, but my battery kept a constant voltage on the drive home, but it was at ~11.8 volts instead of the usual ~14 volts.
is it possible something is just grounding out and sapping the electricity?
how do I find out what hte culprit is. how can I test teh alternator? the battery?
would it be cheap to just take it to a shop and have them check the battery and alternator?
thanks in advance guys.
it's always something... sigh
Originally Posted by saiko_cl_duck
got an Autozone or Advance? Go to them and they can check it for free man.
I heard if you put a piece of metal up to your alternator while it was running it would grab the metal like a magnent if it is working (while running). Other than that sounds like alternator is going.
Originally Posted by Cocoa
unplug the battery while it's running, the car should continue to run if the alt works.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by CLevr098
if that whining sound is accompanied by a slight "burning" smell, its in all likelyhood (sp) your alternator.......same thing happened to me when mine died.....real easy to replace tho
Good luck.
Originally Posted by ghost_masterCL
how can I tell if the belt is slipping? It's a fairly old belt I think.
When you replace it, give her new belts... Go OEM for sure, unless you are like me with pulleys. The stock belts don't quite fit right. My ALT belt had to be (I think) 3 cms longer than the OEM... Just be aware if you have performance pulleys.
I'm only at 75k miles and as far as I can tell visually the belt looks fine, but the line on the belt tensioner seems like it's a bit past the mark it should be. does this mean the belt is too long, or that the auto tensioner is broken in some way?
MrHeeltoe
20
02-23-2023 02:54 PM
MetalGearTypeS
08-29-2016 09:28 PM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
