apexi vafc
Moderator Alumnus
Swaps? $3000 for 50HP? :(
OK. All of these will be looking at the wires with the connectors in the
ecu. The top will be the part with the push tab.
The Red and orange both go to the yel/blk wire on the 32 P connector #11 top
right corner.
The Blk and Brn both go to the Blk wire just to the left of the #11 above.
Note the Brn wire needs to be closer to the ECU.
The Grn wire goes to the 32P connector Yel/Grn Wire #20. This is down one
row and left 3 columns. It should be the one with nothing in the row above
it (an empty spot).
The grey wire goes to the 16P connector (the smallest) Red/Blk wire. In the
top row all the way to the left.
The Blue wire is not used
The pink wire goes on the car side of the cut 32P connector #8 Grn/Yel wire.
Its the wire two to the left of the Blk wire for the ground. The Purple
wire goes on the ecu side of the same wire. Make sure they dont connect
bypassing the VAFC.
The White wire goes on the car side of the cut MAP sensor wire. This is on
the 16P connector white/yellow wire two wires to the left of the Throttle
Positioning Wire. The ecu side of the cut wire should get the yellow wire
from the VAFC.
I'll try to get pics of the manual I used and send them to you. I havnt
found any of the Apexi diagrams to be correct (the auto timer was wrong
too).
This will at least get you colors
Good luck
right corner.
it (an empty spot).
bypassing the VAFC.
from the VAFC.
too).
Good luck
Evolution
OK I just read 1gen entire post.... So is it correct when they said that the 3.0 has a different wiring in the ECu than the 2.2 and 2.3? The only manual I got for my car is the one from advanced auto for the accord/cl. Will that be sufficient?
What other hook ups need to be made for the install of the VAFC>??
