Anyone ever use an oil stop leak product?
1 Post
I'm not sure if it's a combination of sea foaming the crank or switching to synthetic but I'm leaking a small amount of oil. Besides the tiny tiny leak and likely burning a small amount of oil because of how old the car is I figure If there is a product that actually works I might be able to catch this now and plug it up before it gets worse.
I also put in regular synthetic instead of high mileages which likely didn't help.
So, has anyone used a stop leak on their engine oil that has had success or would recommend something to try?
keep that shit out of your engine... find the leak and replace the gaskets. if its internal then decide what you wanna do, i wouldnt ever use that stuff.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
You don't want that buildup crap
1 Post
Just figured I would ask. I have no experience with any of that stuff. I know people have used radiator stop leaks but that's a different situation obviously.
I'll just keep my eye on her if I've got to feed her a quart or two a month so be it.
1 Post
radiator stop leak is fine because coolant is all water based, oil is obviously not. the combination of the oil + the sealant causes nasty inconsistencies in the interior of your engine. the only thing id suggest doing is maybe using a silicon gasket product and resealing all your gaskets. depending on the gap, you may be able to get it from the outside, especially on the valve cover.
1 Post
the expensive ones lol
you get what you pay for with gaskets, just keep that in mind. If you get a metal or alloy gasket set.. make sure that you get one that matches the expansion rate of the metal in your engine. The F is alluminum alloy, im not sure what the J is. either way, a metal gasket is useless if it has a different expansion rate.
6spd FTW
I am guessing it is in the same spot on the F23's as the F22's. It will have one wire coming straight out of it, you will need a 24mm deep socket to change it too. I think I paid like $25 at autozone for a new one.
Do NOT use those things...
mada51589
05-03-2022 08:54 PM
IIDXholic
10-08-2015 07:53 AM
