Antenna plug cut...
I have my stereo in my car hooked up and it sounds great, but the only thing i can listen to is CD's or my iPod. Sometimes i wanna listen to the radio but my antenna plug is cut. I guess it happened when my radio was stolen. Is there anyway to fix this? or where do i get a new one
junkyard? check to see whats on the other end of the antenna cord. worst case scenario cut the plug and some wire from another cl and solder it onto yours?
Yeah it's just Coax cable. You can go to any install shop such as a Bestbuy and pick up a short extension to either splice in or replace it. I do believe that down under the radio on top of the "trans" tunnel there is a place you can unplug the antenna and plug in a new one. A 24" extension antenna would work just perfect, although a 12" might make it as well.
http://www.bestbuy.com/site/Metra+-+...able&cp=1&lp=3 This is basically what you need. |
